Hi again. First ftp. I can connect to Tiny4412 using ftp. But when I try to put/get/ls, system gives me: 500 Illegal PORT rejected (address wrong). ftp: bind: Address already in use And now, sftp. If I try sftp plg@192.168.1.200, the system gives me: subsystem request failed on channel 0 Couldn't read packet: Connection reset by peer I need a right way to put execute QtCreator apps on Linux FriendlyARM using ftp or sftp. Can some one help me????
ftp and sftp
It works now!!!! In /usr/local/etc/sshd_config Line: Subsystem sftp /usr/libexec/sftp-server must be: Subsystem sftp /usr/local/libexec/sftp-server
Dude I'm having the same problem in Tiny4412 and I did as you said but it didn't solve my problem. Can anybody help me?
Yeah I had no problem with Mini2440 regarding FTP but apparently Tiny4412 does have a problem with FTP & SFTP. Any idea whats causing this?
Please explain more. How should I do that? You mean I should look for a shared object file? If yes then which specific file ?
