strange things in nor mode
mateo
hello,
I have recently buy a mini6410. The board boot normally in NAND mode ,all
things are good (serial port, touchscreen, launching applications,console
on serial port, ...) but when i start the board in NOR mode, the screen is
white and very quickly some lines appear on the left half and the right
half is dark and i have nothing into the console(that is embarrassing).
I need help because that is embarrassing...
Thanks for help!
What do you expect to happen in NOR mode?
mateo
I guess, talk to the bootloader with serial port but their is nothing.
Dave Festing
OK, it wasn't clear what you were trying to do.
How have you set up the terminal program you are running on the host?
Dave Festing
Have you got the correct RS232 cable for a mini6410?
mateo
I try to talk to the bootloader (switch in nor position)
my terminal conf: 115200, 8 bit, parity:none, flpw control:none.
What do you mean about the correct RS232 cable ? (My board is a second hand
product and i use the rs232 cable from the box)
If it is the original RS232 cable that came with the unit and it worked
before you should be OK.
The mini2440 uses a different RS232 cable than the mini6410.
Does it still work in the NAND position?
I would suggest you start another thread and put mini6410 in the title and
maybe someone who actually uses the 6410 will come to your rescue.
mateo
I don't know I ask him and yes the board work in NAND position
