Hello, I Got my Mini 2440 board(1 GB)with the superboot installed on it. I used http://www.friendlyarm.net/forum/topic/5391 these instructions to convert it to suppervivi and use DNW to transfer zImage. I used zImage_A70 and zImage_A70i present on DVD transfered using DNW. Before that I transfered supervivi-128M. But the problem is my touchscreen is not working. Touch calibration program opens at start but it doesn't respond. Anyone with same issue or with solution for this??
Touchscreen not working
Hi Ajit, What is ur LCD Model? You have to load the zImage of the particular model Compatible LCD only.
Now Touchscrren Driver Changed as compare to previous. So you need to used new kernel source code and then compile kernel and used that kernel.
