Hello, I want to glow an LED on the GPIO and have written a program to modify the registers. I have managed to write to the physical addresses of the GPIO port B, as seen in 2440addr.h, but the voltage values are not coming as expected. my control register rGPBCON = 0x5555; pullup register rGPBPUL = 0xff; data register rGPBDAT = 0xf0; I have made all the pins as output and have switched on the pins GPB0,1,2,3. But when I check with a multimeter on GPB0 and GPB1, GPB0 has a voltage of about -2.1V (with COM conected to ground and the red terminal connected to GPB0)and GPB1 has a voltage of -0.3 V. What could I be doing wrong?
Unable to get a high output on a GPIO pin
Okay, on further investigation, it seems that somehow, the ground pin and the VCC 3.3V pin functions got interchanged. However, modifying registers still doesn't do anything, whereas now setting the pin value using the sysfs method is working. I have attached my code Thanks!
