iam working in embedded devices and trying to install linux kernel 3.15 on the device friendlyARM 6410 . but there are a lot of diffrences between the default kernel (2.6.38) and target kernel .
need to install linux kernek 3.15 on friendlyARM 6410
I could give you a few hints, but they will probably require a fair bit of work. Why do you need 3.15?
Hmmm. In the 3.15 mainline is there any config files for the mini6410. Think so, but most likely need patching. There is a Pengutronix BSP for the 6410, but I doubt the kernel version is beyond 3.7 or 3.11 Have a look.
Then I guess it is a "USB mass storage device" from the Mini6410/Tiny6410 point of view (like a memory stick). Just enable the support for such kind of USB device in the kernel and it should work.
