tiny 2416 Wince install error
STR_344
I created the sd card, but if you could help setup does not start
lsk
You just posted 3 posts with different forums mode?
Not much help better = ="
Btw, did you make sure that your board's 'SD/NAND switch' is switched to
"boot from SD" ?
if yes, make sure images/FriendlyARM.ini is right for booting from SD to
install OS.
STR_344
SD CORRECT POSITION SWITCH,SELECTED OS TRUE BUT DOES NOT START LOADING.
Beep sound is not,Led is not MAY CAUSE ?
lsk
Did you use SD-flasher to complete SD preparation?
Is that says complete after fusing SD ?
lsk
Make sure that files for Linux set in FriendlyARM.ini is ALL right for your
device!
check all the files set that they really exist in and images/winCE.
make sure there's right bootloader, fs, etc.
lsk
will be better to tell me step-by-step you did.
STR_344
DVD contains superboot 2451,Is this the appropriate boot ?
tiny 2416 is coming my tiny bootloader installed ?
may need to install with H-JTAG ?
lsk
if you install with SD card you'll need only SD card I guess (I'm not sure
with 2416 but thought it won't be different).
First, fuse SD card with SD-flasher.exe (If windows 7, just ReLayout
before).
Then create images folder on SD, copy all your needed files for booting and
installing OS. and config file FriendlyARM.ini.
That'll be all what you have to do, did you?
lsk
I guess file superboot 2451 is just file you have to use on fusing SD.
But the another file for installing OS must be something with nand-128/256
lsk
Ouch! for wince maybe nboot-?-128/256
STR_344
Thanks.
This process is true, but I got negative results.
lsk
see at 2.1 and 2.2 in this
http://embeddedforus.4umer.com/t8-porting-linux-on-tiny-6410-mini-6410-f...
your process might be similar to this.
STR_344
the same steps,I understand the problem
STR_344
sd card support is not installed
STR_344
Do you have any alternative suggestions on the subject
lsk
I don't know what exactly you're facing.
you have to describe it clearly.
It's not starting? Nothing on screen when you boot from SD?
Or there's some error?
Or the problem is in the SD preparation step?
