I download the UBUNTU image for NanoPC from http://pan.baidu.com/s/1sjNgenF NanoPC can not boot, It stuck with following text : plymouthd: ply-terminal.c:611 ply_terminal_open: Assertion 'terminal !=(void*)0' failed. I do not use HDMI I use FA-S700 LCD Please anybody can help me to solve this boot problem Saiful
NanoPC Ubuntu can not boot
I would suggest searching on the RaspberryPi forum. Think I saw some threads there that looked similar.
Thanks davef for your suggestion When the screen show the text : plymouthd: ply-terminal.c:611 ply_terminal_open: Assertion 'terminal !=(void*)0' failed. I press Ctrl-Alt-F1 it bring me to login terminal, asking login name and password. I try many username t1,Guest, blank without success Is there any info what is login name and password should I use ? Regards Saiful
OK, Now I got the solution Usernama : t1 password : 123456 Now, I can go to terminal login. But when I run startx, I get blackscreen Please anybody help me .. Saif
I really need help. This is the last part of my Xorg.1.log [ 127.595] (EE) MALI(0): mali_drm_open_master DRM OPEN (fd: 0x9) [ 127.595] (EE) MALI(0): mali_drm_open_master DRM failed to interface version [ 127.595] (EE) MALI(0): Failed to be master of DRM! [ 127.595] (II) UnloadModule: "mali" [ 127.595] (EE) Screen(s) found, but none have a usable configuration. [ 127.595] (EE) Fatal server error: [ 127.595] (EE) no screens found(EE) [ 127.595] (EE) Please consult the The X.Org Foundation support at http://wiki.x.org for help. [ 127.595] (EE) Please also check the log file at "/var/log/Xorg.1.log" for additional information. [ 127.595] (EE) [ 127.604] (EE) Server terminated with error (1). Closing log file. Booting process stop, and command prompt I hope somebody can help me Saif
