Hello, In our codes we are performing a few simple arithmetic operations on float value. It works fine when compiled with gcc but when we compile with arm-linux-gc-4.3.2 (no errors while compiling) and run it on the board, we get a runtime error : 'illegal instruction'. All instructions and print statements before this particular operation work fine. The operation we are doing is : float value; int a = 307; value = a * 3.3 / 1023.0; Also, in another code, we have the following operation float a,b; scanf("%f",&a); b = 1- a; This works fine when the value of a is less than 0.5, but gives an illegal instruction when a > 0.5. Is there anyone who gets the same problem? We tried fixed point arithmetic as well, to no avail. (still getting illegal instruction). Thanks and regards
Floating point trouble
I tried enabling all the Floating point emulations in the kernel during the step 'make menuconfig', recompiled the kernel and reloaded the zImage. The following 3 floating point emulators were available(I enabled all): NWFPE math emulation Support extended precision FastFPE math emulation(EXPERIMENTAL) Then I tried compiling the program with following options: -msoft-float -D__GCC_NOT_NEEDED -march=armv4 -mtune=920t -msfloat-abi=soft -D__GCC_NOT_NEEDED -march=armv4 -mtune=920t I am still getting illegal instruction while executing.
Did you build your whole root file system with this compiler? If not, and you mix applications built with different compiler this kind of failure can happen. Another source of trouble can be the pre-configured optimization of the compiler. Four your Mini2440 you must ensure your compiler (and all its libryries) must be build for: $ readelf -A <your-self-compiled-file> Attribute Section: aeabi File Attributes Tag_CPU_name: "4T" Tag_CPU_arch: v4T Tag_ARM_ISA_use: Yes Tag_THUMB_ISA_use: Thumb-1 Tag_FP_arch: VFPv2 Tag_ABI_PCS_wchar_t: 4 Tag_ABI_FP_rounding: Needed Tag_ABI_FP_denormal: Needed Tag_ABI_FP_exceptions: Needed Tag_ABI_FP_number_model: IEEE 754 Tag_ABI_align_needed: 8-byte Tag_ABI_align_preserved: 8-byte, except leaf SP Tag_ABI_enum_size: int Compare this output with the output of a file from your root filesystem on the Mini2440. They should be the same.
Thanks for the reply Juergen. The readelf command on the PC kernel gives the following output for a file compiled by me: $ readelf -A <your-self-compiled-file> Attribute Section: aeabi File Attributes Tag_CPU_name: "ARM10TDMI" Tag_CPU_arch: v5TE Tag_ARM_ISA_use: Yes Tag_THUMB_ISA_use: Thumb-1 Tag_ABI_PCS_wchar_t: 4 Tag_ABI_FP_rounding: Needed Tag_ABI_FP_denormal: Needed Tag_ABI_FP_exceptions: Needed Tag_ABI_FP_number_model: IEEE 754 Tag_ABI_align_needed: Yes Tag_ABI_align_preserved: Yes, except leaf SP Tag_ABI_enum_size: int However, on the mini2440 terminal, it says : '/bin/sh:readelf:not found' So I was not able to compare both the outputs. Also, I did not build the root filesystem on my own. I had an image 'rootfs_qtopia_qt4.img' which I dumped onto the board using supervivi transfer tool. Should I try building a new root filesystem now? Thanks a lot!
As you can see in the output of the "readelf" command your own software is made for an ARMv5 CPU. But the CPU on the Mini2440 is of type ARMv4. Your code must crash, and it is not a problem of the floating point instructions! > However, on the mini2440 terminal, it says : '/bin/sh:readelf:not found' Sure. You must copy one file from its root file system to your host to be able to run the check. > Also, I did not build the root filesystem on my own. Then you must know how this root file system was built. To add your own software to this existing root filesystem you must use the same toolchain to make everything consistent. > Should I try building a new root filesystem now? If you rely on it, you should do so. Otherwise you will get many funny error messages if you mix binaries from different sources.
dear all, 1- has Nanopi (1) a HW float point unit ? 2- wich cflags must i use for float point ? thx, julio PS: running nanopi 4.1.2-FriendlyARM uname -a shows armv5tejl cat /proc/cpuinfo shows: ARM926EJ-S rev 5 arch: 5TEJ hw: MINI2451 readelf compiled_application -a shows: Tag_CPU_name: "4T" Tag_CPU_arch: v4T from ARM manual: The ARM926EJ-S processor provides support for external coprocessors enabling floating-point or other application-specific hardware acceleration to be added. The ARM926EJ-S processor implements ARM architecture version 5TEJ.
