Hello, The problem of our USB drives not getting recognized when we try to connect the mini2440 to our PC has come to the extent that we hav to halt our work because we can't transmit a simple code of dump a zImage onto the board. Also, I recently switched to a different, newer computer with USB ports that are confirmed to work, and after working once, it stopped recognizing it again and gave me a bsod. I have downloaded and installed the firndlyarm usb driver sfrom the site and the driver for our serial cable too, and both of them said succesfully installed and ready to use. I even transmitted one code and then now it refuses to work. On restarting the computer, it takes wayy longer than normal to shutdown. What seems to be the issue here? I think it is more than just normal USB failure. Thanks and regards!
USB driver is not recognized
Which OS(Version) of PC you're using? After you install USB download driver, do you see in the device manager that there is device for FriendlyARM USB appear? If not, try to use VM as very basic windows XP.
