What does error message mean?
tuna
My bord is below.
http://www.friendlyarm.net/products/tiny6410
Tiny6410 SDK v1.2
I want make(makefile) a sample source. But I can not complete
make(makefile).
I do not understand the meaning of the error messsage.
Please tell me solution.
1. 86:3: error: impossible constraint in 'asm'
 line 86 --> FD_ZERO(&rds);
2. 98:14: error: impossible constraint in 'asm'
 line98 --> } else if (FD_ISSET(led_control_pipe, &rds)) {
      makefile
KERNEL_SRC = /*** Path*****/arm6410/linux-2.6.38
BUILD_DIR := $(shell pwd)
EXTRA_CFLAGS = -I/*** Path*****/include
MODULES = led-player_Test.o
obj-m := $(MODULES)
CROSS_COMPILE = arm-linux-
ARCH = arm
MAKEARCH = $(MAKE) ARCH=$(ARCH) CROSS_COMPILE=$(CROSS_COMPILE)
all:
  $(MAKEARCH) -C $(KERNEL_SRC) SUBDIRS=$(BUILD_DIR) modules
clean:
  rm -f *.o
  rm -f *.ko
  rm -f *.mod.c
      All of sample source
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/ioctl.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <sys/select.h>
#include <sys/time.h>
#include <string.h>
static int led_fd;
static int type = 1;
static void push_leds(void)
  static unsigned step;
  unsigned led_bitmap;
  int i;
  switch(type) {
  case 1:
    if (step >= 6) {
      step = 0;
    if (step < 3) {
      led_bitmap = 1 << step;
    } else {
      led_bitmap = 1 << (6 - step);
    break;
  case 0:
    if (step > 255) {
      step = 0;
    led_bitmap = step;
    break;
  default:
    led_bitmap = 0;
  step++;
  for (i = 0; i < 4; i++) {
    ioctl(led_fd, led_bitmap & 1, i);
    led_bitmap >>= 1;
int main(void)
  int led_control_pipe;
  int null_writer_fd; // for read endpoint not blocking when control
process exit
  double period = 0.5;
  led_fd = open("/dev/leds0", 0);
  if (led_fd < 0) {
    led_fd = open("/dev/leds", 0);
  if (led_fd < 0) {
    perror("open device leds");
    exit(1);
  unlink("/tmp/led-control");
  mkfifo("/tmp/led-control", 0666);
  led_control_pipe = open("/tmp/led-control", O_RDONLY | O_NONBLOCK);
  if (led_control_pipe < 0) {
    perror("open control pipe for read");
    exit(1);
  null_writer_fd = open("/tmp/led-control", O_WRONLY | O_NONBLOCK);
  if (null_writer_fd < 0) {
    perror("open control pipe for write");
    exit(1);
for (;;) {
     fd_set rds;
     struct timeval step;
     int ret;
[line 86] ---->   FD_ZERO(&rds);
    FD_SET(led_control_pipe, &rds);
    step.tv_sec  = period;
    step.tv_usec = (period - step.tv_sec) * 1000000L;
    ret = select(led_control_pipe + 1, &rds, NULL, NULL, &step);
    if (ret < 0) {
      perror("select");
      exit(1);
    if (ret == 0) {
      push_leds();
[line 98] ---->  } else if (FD_ISSET(led_control_pipe, &rds)) {
      static char buffer[200];
      for (;;) {
        char c;
        int len = strlen(buffer);
        if (len >= sizeof buffer - 1) {
          memset(buffer, 0, sizeof buffer);
          break;
        if (read(led_control_pipe, &c, 1) != 1) {
          break;
        if (c == '\r') {
          continue;
        if (c == '\n') {
          int tmp_type;
          double tmp_period;
          if (sscanf(buffer,"%d%lf", &tmp_type, &tmp_period) == 2) {
            type = tmp_type;
            period = tmp_period;
          fprintf(stderr, "type is %d, period is %lf\n", type, period);
          break;
        buffer[len] = c;
  close(led_fd);
  return 0;
fd_set rds;
What does this mean?  Thought I knew a fair bit of C, but I don't recognise
this.
Juergen
What do you try to compile? A regular application or Linux kernel code?
From the Makefile it seems to be Linux kernel code. From the source it
seems a regular application. You can't mix it.
tuna
Thank for your reply
>>>>>fd_set rds; What does this mean?
This source cpde supplier said
 "FD_SET" is linux system command.
 "rds" is to use linux pipe.
Since I don't know in detail about sourcr code, because I'm not making its
software. I got this source code below.
http://kanebebe.dip.jp/download/ARM11-6410-DVD/Linux/examples-mini6410-2...
I am going to make a kernel object file ( *.ko ) from c source file, in
isolated directory from the kernel source.
( If necessary, use is "insmod" or "rmmod".)
Juergen
Then you should use only include files from the kernel itself!
But your code is using "#include <stdio.h>" for example. This is the
application side. The kernel itself does not have stream IO!
Your source code seems not to be intended as a kernel module!
Juergen
And the sources from the Link you mention are application code. And it
already comes with Makefiles. Don't use a Makefile from the kernel sources.
tuna
Thank you.
For information on how to make kernel module and sample source, I seemed to
lack of understanding.
