Hi, all. I'm learning on tiny6410 board and working on Linux OS. After so many times burning to test my board, Now I'm going to set some files on it (such as test application / tslib ). But! the board appear an error "cp: write error : No space left on device." "cp: can't create '/usr/...': Cannot allocate memory" Even I burn new Linux place on it, Can't fix. Is it because there're old files from previous OS (Linux/WinCE/Ubuntu) still on board's storage? How can I fix it? Can I flush the device for burning new OS? Thanks.
Tiny6410 : no space left on device
Ps. for now I cannot use RS232 to connect device cause of using laptop. Have only USB/LAN/SDCard. Any suggestion ?
Maybe, link us to the instructions you are following to put the new image into flash might help. Years ago I had to do a NAND scrub as put of the process, now with the way the Pengutronix kernel and root file system are setup I just erase the old kernel, ie: sudo dd if=/dev/sdb? of=/dev/zero then copy the new kernel using dd as well. Are you using dd?
With installing new kernel I'm using superboot via SD. It causes no error here. But, my problem is for now my tiny's nand flash space used 250/250 Mb as rep1's attachment. So, I can't put my file to my tiny anymore. Wanna know how to format nand flash without serial port connection. Cause now I'm having a problem with the serial so much, I used USB-to-serial and install all driver and my laptop saw the serial port already. But when I turned on the board (with FriendlyARM.ini set CheckOneButton=Yes ), there's nothing in serial terminal. Is this board use cross serial cable? I'm using Laptop's USB port <-> USB-to-serial adapter <-> femail-femail straight serial cable <-> Tiny6410's COM0
All I recall is that the RS232 cable for mini2440 and the mini6410 are different. Sorry, I can't say for certain which way it is. Try searching the forum it was discussed quite often in the early days. Didn't you get a RS232 cable in the kit?
