What is the basic difference between the Stamp Module and SDk Board?? Can we use Stamp Module as the SDK Board??
Difference between "stamp module" and SDK board
Hi Sandeep.. But what is difference in construction and working??? can micro2440 will work like mini2440??
Hello Ajit, For Construction, Mini2440 has 4 layer PCB and Micro2440 has 6 layer PCB. Working of both board depends on firmware/software you are using. Yes, Micro2440 will work like mini2440.
Can we use the stamp module of micro2440 i.e. CPU+Required memory without the SDk board i.e. other hardware provided with it.??
