Hello, I have an USB-Wifi Dongle with an Realtek RTL 8188S chip. I am running the FriendlyARM 2.6.38 kernel running on the Mini 6410. Which is the right module for this dongle and how to get the wlan0 device? greetings Holger
USB Wifi RTL888S
Hi Holger I did try it with RTL8192CU like you I got a driver source from realtek http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid... # insmod 8192cu.ko [ 26.500000] rtl8192cu driver version=v4.0.2_9000.20130911 [ 26.500000] build time: Jan 18 2016 16:18:46 [ 26.510000] [ 26.510000] usb_endpoint_descriptor(0): [ 26.510000] bLength=7 [ 26.510000] bDescriptorType=5 [ 26.520000] bEndpointAddress=81 [ 26.520000] wMaxPacketSize=200 [ 26.520000] bInterval=0 [ 26.530000] RT_usb_endpoint_is_bulk_in = 1 [ 26.530000] [ 26.530000] usb_endpoint_descriptor(1): [ 26.540000] bLength=7 [ 26.540000] bDescriptorType=5 [ 26.550000] bEndpointAddress=2 [ 26.550000] wMaxPacketSize=200 [ 26.550000] bInterval=0 [ 26.550000] RT_usb_endpoint_is_bulk_out = 2 [ 26.560000] [ 26.560000] usb_endpoint_descriptor(2): [ 26.560000] bLength=7 [ 26.570000] bDescriptorType=5 [ 26.570000] bEndpointAddress=3 [ 26.570000] wMaxPacketSize=200 [ 26.580000] bInterval=0 [ 26.580000] RT_usb_endpoint_is_bulk_out = 3 [ 26.580000] [ 26.580000] usb_endpoint_descriptor(3): [ 26.590000] bLength=7 [ 26.590000] bDescriptorType=5 [ 26.590000] bEndpointAddress=84 [ 26.600000] wMaxPacketSize=40 [ 26.600000] bInterval=1 [ 26.600000] RT_usb_endpoint_is_int_in = 4, Interval = 1 [ 26.610000] nr_endpoint=4, in_num=2, out_num=2 [ 26.610000] [ 26.610000] USB_SPEED_HIGH [ 26.610000] CHIP TYPE: RTL8188C_8192C [ 26.620000] register rtw_netdev_ops to netdev_ops [ 26.620000] Chip Version ID: VERSION_NORMAL_TSMC_CHIP_88C. [ 26.630000] RF_Type is 3!! [ 26.630000] EEPROM type is E-FUSE [ 26.640000] ====> ReadAdapterInfo8192C [ 26.640000] Boot from EFUSE, Autoload OK ! [ 26.780000] EEPROMVID = 0x0bda [ 26.780000] EEPROMPID = 0x8176 [ 26.780000] EEPROMCustomerID : 0x00 [ 26.790000] EEPROMSubCustomerID: 0x00 [ 26.790000] RT_CustomerID: 0x00 [ 26.790000] _ReadMACAddress MAC Address from EFUSE = 90:9f:33:ec:f5:93 [ 26.800000] EEPROMRegulatory = 0x0 [ 26.800000] _ReadBoardType(0) [ 26.810000] BT Coexistance = disable [ 26.810000] mlmepriv.ChannelPlan = 0x02 [ 26.810000] _ReadPSSetting...bHWPwrPindetect(0)-bHWPowerdown(0) ,bSupportRemo teWakeup(0) [ 26.820000] ### PS params=> power_mgnt(1),usbss_enable(0) ### [ 26.830000] ### AntDivCfg(0) [ 26.830000] readAdapterInfo_8192CU(): REPLACEMENT = 1 [ 26.840000] <==== ReadAdapterInfo8192C in 200 ms [ 26.840000] rtw_macaddr_cfg MAC Address = 90:9f:33:ec:f5:93 [ 26.850000] bDriverStopped:1, bSurpriseRemoved:0, bup:0, hw_init_completed:0 [ 26.870000] _rtw_drv_register_netdev, MAC Address (if1) = 90:9f:33:ec:f5:93
