Problems with DNW
Samyukta Ramnath
I wanted to try using the DNW software to send codes to my board in order
to avoid the hectic usage of USB pen drives for the same. So I opened the
dnw.exe file, connected the board to the computer using a serial cable and
a USB cable, booted the board in the NOR mode and then pressed "connect".
It said on the menu bar : [COM1 :115200bps][USB:OK][ADDR:0x30000000]
The speed and the addresses were set according to the manual that I have
for FriendlyARM mini2440.
After pressing refresh button on the board however, nothing happened. I was
expecting the dnw menu to appear with options like
[1] Download WinCE boot logo
[w] Download WinCE NK.bin
and so on.
What could be the problem here?
Thanks!
Regards
Samyukta Ramnath
Also, I forgot to ask, in case I don't want to use DNW, is it possible to
dump zImage of the kernel on the board via another way, say, USB? I want to
access some pins on the board and in order to do that I had to configure
the kernel for supporting those pins.
Thanks!
Sandeep Sondagar
Hello Samyukta,
DNW works with only supervivi.
Nowadays, FA ships mini2440(may be others too) with Superboot (Closed
Source boot-loader) on NOR. This new boot-loader enables Mini2440 setup via
SD card and USB (using tool called minitools). "Very Simple and Very Fast."
I am beginner. Correct me if i am wrong.
Ajit
Hi Sandeep,
Yes you are right.. But do you know how to boot from sd card???
