davef, NAND flash is not working on my micro2440 board.
NAND flash
Mine seems to be working OK, so I haven't needed to try to fix it. Maybe, some more details and someone else could help. Did it ever work? What did you do before it stopped working? Does NOR still work? Did you put more than 5Volts on the board?
actually I have developed application on non os i.e on ADS1.2 and this application works fine from RAM but stops when loaded into NAND flash. but the example program given in the DVD works fine in NAND. please can u help me what may be the problem
Vikas If you are trying to 'run' your program in the NAND flash then it won't work. It will have to be loaded into RAM to be executed. Phil
Phil, But i want to make my application to start when power is on i.e application should start automatically from flash when power is switched on.
