Linux Boot Logo
Ajit
What is the easiest way to change the boot logo on the
mini2440 from the penguin?
Sandeep Sondagar
Hello Ajit,
To change boot logo you need to compile kernel.
Use following commands to change logo.
convert my_logo.png temp_lopo.ppm
ppmquant 224 temp_logo.ppm > temp_logo2.ppm
pnmnoraw temp_logo2.ppm > logo_linux_clut224.ppm
copy logo_linux_clust224.ppm to [path_to_Kernel]/driver/video/logo/
Cross compile Kernel with "make -j4 zImage"
Ajit
Should I directly type these commands in terminal?? Is there any size limit
for the logo??
Thanx for your reply.
Ajit
My zImage is placed in /home/ajit/Desktop/Kernel/zImage_A70.. But When I
type cp logo_linux_clust224.ppm
/home/ajit/Desktop/Kernel/zImage_A70/driver/video/logo/..
it says Not a directory..???
Sandeep Sondagar
Yes, You need to type these commands directly in terminal.
Maximum size is display Resolution (320x240) and input format png.
type "cp logo_linux_clust224.ppm
/home/ajit/Desktop/Kernel/zImage_A70/driver/video/logo/logo_linux_clust224.ppm"
Ajit
Thank You Sandeep.
For Your Support.
Ajit
It still says Not a directory..
Sandeep Sondagar
Ajit,
This is Very confusing.
I have already said that you need to Cross-Compile the kernal to Change the
logo. And you are trying to add your logo to zImage
[/home/ajit/Desktop/Kernel/zImage_A70].
Again,
cp logo_linux_clut224.ppm
[path_to_Kernel_Source_Code]/driver/video/logo/logo_linux_clut224.ppm
Then compile kernel for your A70 display.
Ajit
What is "Kernel_Source_Code" ??? Where can I get it ???
Sandeep Sondagar
You can Download kernel source code from download section.
http://www.friendlyarm.net/dl.php?file=linux-2.6.32.2-mini2440_20110413.tgz
Here is a good tutorial to compile kernel-
http://www.youtube.com/watch?v=OzrxEIAHdxo
Ajit
Thank You Sandeep..!!
Ajit
Thank you for your support..
Should I follow all steps shown in above tutorial???
Or
what I did is
Copied my logo file in that address.
configured with A70 .config file
and "make -j4 zImage"
Will it work or I Should do the "menuconfig" too as shown in video??
Sandeep Sondagar
Ajit, You don't need to follow all the steps.
you dont need to do "make menuconfig"
Sushant Bhangales
Convert image using logomkaer software inside the DVD.
Sandeep Sondagar
Attachment: Cursor.jpg (62.04 KB)
Dear Sushant,
Can you guide us to remove blinking cursor at the top corner?
See attached Image..!
Ajit
Hey Sandeep
You got any solution??
