Sundeep, Could you briefly describe how you are controlling devices via the internet? Is this via a ADSL connection or ? Thanks, dave
Device control via internet
Hi Dave Using Port Forwarding i am controlling the devices over the internet, but cant able to stream the camera over internet IP address. Any idea abt it?
Sundeep, No idea about video streaming. Are you able to do it over your local network? Port forwarding ... yes, but on a landline, ie ADSL? Or on a SmartPhone?
Putting "video streaming over the internet" provides a lot of reading! What do you use on your intranet? VLC? Which platform are you running this on? mini2440?
on linux platform using mjpg streaming algorithm i can able to steam the video over the intranet,i am using BOA webserver on the machine
Can BOA handle the the content? Looking at one site http://www.codeproject.com/Articles/371955/Motion-JPEG-Streaming-Server seems video streaming is done or can be done via HTTP. When I had a look at BOA I recall having to learn CGI, because as far as I understand it couldn't handle HTTP. I run thttpd enabled for PHP5, but haven't tried to stream video over it so can't tell you if that would be more successful. This topic has been hi-jacked again. You have a go at starting one that addresses your particular problem and link to this one!
Think I have mixed up my terms here: let's change it to BOA can't handle HTML. I was reading through the early mini2440 user manual and there is an example of running a USB webcam over the internet.
