Hi everyone,
I just started with FreindlyARM (mini2440).
I try to ON some pin on GPIO. I need 6 pin to control (on/off).
I write program in C#, but unfortunetly that didn't work. I found one
similar project and try to use it in my project. In attachment is whole
project in VS 2008 C#. Here is little preview of my code:
namespace SmartDeviceProject2
public partial class Form1 : Form
private Pin _led1, _led2, _led3, _led4;
private Pin _switch1, _switch2, _switch3, _switch4, _switch5,
_switch6;
public Form1()
InitializeComponent();
private void button1_Click(object sender, EventArgs e)
//this suppose to turn on one pin
_led1 = new Pin(Port.PORT_B, 6, PinConfiguration.OUTPUT,
PinValue.HIGH);
private void button4_Click(object sender, EventArgs e)
//this suppose to turn off one pin
PinValue.LOW);
private void button2_Click(object sender, EventArgs e)
//turn on second pin
_led2 = new Pin(Port.PORT_B, 6, PinConfiguration.OUTPUT,
PinValue.HIGH);
private void button5_Click(object sender, EventArgs e)
//turn off second pin
PinValue.LOW);
//blow is some try
private void button3_Click(object sender, EventArgs e)
_switch1 = new Pin(Port.PORT_G, 0,
PinConfiguration.INPUT_WITHOUT_PULLUP);
private void Form1_Load(object sender, EventArgs e)
_switch2 = new Pin(Port.PORT_G, 3,
_switch3 = new Pin(Port.PORT_G, 5,
_switch4 = new Pin(Port.PORT_G, 6,
_switch5 = new Pin(Port.PORT_G, 7,
_switch6 = new Pin(Port.PORT_G, 11,
private void button6_Click(object sender, EventArgs e)
checkBox1.Checked = ((_switch1.Value == PinValue.HIGH));
checkBox1.Checked = ((_switch2.Value == PinValue.HIGH));
checkBox1.Checked = ((_switch3.Value == PinValue.HIGH));
checkBox1.Checked = ((_switch4.Value == PinValue.HIGH));
checkBox1.Checked = ((_switch5.Value == PinValue.HIGH));
checkBox1.Checked = ((_switch6.Value == PinValue.HIGH));
In the end, I need to control 6 pins on GPIO or SystemBus.
http://s29.postimg.org/gl5qswft3/mini2440.png
Maby this work but what is PORT A, B, G
If anyone can help me?
Milan
wincd pinout c# mini2440
Sorry for diley I have some problem with my internet provider I must use C#, I fonund some GPIO library on internet. I import them in project using Mini2440.GPIO; using System.IO.Ports; Where to download drivers, and how to include them in C# or Friendly? If there some working example code, I need just to get HIGH and LOW on some pinout!? Two week can not to solve this. Help! Sorry for stupid questions :-)
Hi, Can u help u out only in linux environment as per your app, as i dont have experience in WinCE side.
Hi, First I thing about Qt enviroment, I install qt on my laptop (using Linux Mint), but I thing that is simplier with WinCe. I have not expirience with Qt, so If you can help me that is also possible solution. Thanks
For start i need to get HIGH signal on 6 pins, and I must to be able to controle then on/off. Second part is to turn it on /off in same time, to get some pulse or clock signal. That signal control some other hardware part of project.
You should find everything you need on my website : http://www.domodom.fr/spip/A-GPIO-driver-for-mini2440.html Best regards domdom
