I have been working with friendlyARM hardware (6410,210, mini210s, mini210, tiny210 etc) for over two years now. I run a customized version of the kernel with a custom install image for android. I can help with almost anything related to getting android running and doing what EVER you want on these boards. I am a native english speaker (from the USA) and have taken the time to sift through all the docs in Chinese and or just find the solution myself. If your in need of help let me know. If I give you some helpful info consider buying me a beer but all advice is free. If you have more detailed help needed we can talk. Good luck to all!
Do you need help? Ask me!!!
Just curious how you expect this to work? Do we preface our questions with "phpn00b"? Which then draws your attention? I thought the procedure was, if you see a question where you might be able to help you just reply. Your first posting on here as well? And a double post at that.
Hi phpn00b! First time I see the help offer :) So, if you'd be so kind, what about the S5PV210 SoC initialization assembler code? I have almost all low-level drivers to write non-OS programs, but the Samsung ROM code inits the interrupts vectors only. I need to intercept/install routines on PABT/DABT/SWI and do memory relocation. Sometimes I will dig them by myself, ready solution may speed up this process. Thanks anyway!
@anatoly sorry to say but that would be over my head. The use case that I have for these boards requires a more full OS like Android. I have never had to go that low level other than rewriting the Samsung UART kernel driver for a special application that we have the needs a non standard bit pattern.
Thanks, I got it. My last non standard UART driver was FriendlyARM's 1-wire touchscreen/LCD interface :)
Dear phpn00b, I bought a tiny210 V2 board last year. To my surprise, the UART driver in WinCe can only receive ASCII codes correctly. If a code over 128 (Extended ASCII Codes) is sent to the board, the driver send the application layer messy. Could you please check the problem?
Hi phpn00b Thanks for your reading my question. I am using FriendlyArm mini210s now. First: How to custom Android Image? I have developed apps for my idea. I want to delete unnecessary apps on Android4.0.3 Image. Second:I want to start my app automatically when power on the device. Would you like help me about this solutions? Best regards. WanChao
I am using the card fusing tool but when i scan it doesn't see the sd card When i click scan on The Friendlyarm sd fuser it cant see the sd card. I tried different cards different PCs different card readers, reformatting, deep formats even tried Win XP (I know this is not good) but still would not read. It shows up on disk management and I can write to it but the fuser wont read it. I looked on line but no one else has this problem. Any ideas Thanks guys and girls
Hi "phpn00b", I've been trying to configure my H43 LCD on my Nanopc-T1 but I didn't have a chance for now. I don't know what specific configuration I need to write in FriendlyArm.ini file, my current config is show bellow : CheckOneButton=No Action = Install OS = Android LowFormat = Yes VerifyNandWrite = No LCD-Type = H43 LCD-Mode = Yes CheckCRC32=No StatusType = Beeper | LED ################### Android #################### Android-BootLoader = Superboot4412.bin Android-Kernel = Android/zImage Android-CommandLine = console=ttySAC0,115200n8 androidboot.console=ttySAC0 ctp=2 skipcali=y vmalloc=512m Android-RamDisk =Android/ramdisk-u.img Android-RootFs-InstallImage = Android/system.img Android-UserData = Android/userdata.img I don't know if I need a LCD Adapter board in order to change the voltage from 1.8 to 3.3. The H43 datasheet-manual says that it works with -0.5 to 5V. The LCD shows a white screen and the touchscreen does not work. Any suggestions? Warm Regards
Hi, I need to mount the pen drive in Tiny 210, after i inserted the pen drive , i clicked on the app "usb storage". It gave out a message as "USB storage is not mountable". Please let me know how to mount this pen drive. I also dont know how to SSH to this device, any instructions related to this would be of great help. Thanks
I friendlyArm users with Mini2440 series w35, I functioned as an automatic school bell. when I change the contents of difile '' bell 'after that I save. I use WinSCP for editing process. but scrips autorun config it does not want to walk. berlajan remain with the old config. if it needs a terminal command? if yes, what are his commands? please help me thank you in advance
Hello, I have a nanopc-t1 with ubunto pre installed. And to activate hdmi on device, I have to use minitool software via my pc on windonws 7 64 bits. But when I launch minitool software, it doesn't see the board connected. I followed the process and the board seems to be in boot mode. But I suspect the problem come from the detection of the device from the usb port of my computer. I tryed this method https://www.raymond.cc/blog/loading-unsigned-drivers-in-windows-7-and-vi... But it doesn't work. Do you have an idea ? Thank you for your help.
Hi phpn00b! I am working on mini2440 board. I am a collage student and i want to develop a application in which, i will connect 4 senor on gpio pin. How can i read digital '0' and '1' over the pins. In this application i need respond time of 1 msec so i can read the status of sensor with time resolution of 1 msec. it will increase my accuracy. Can i achieve using this board. I need a expert advice and some guidance too. Thanks Jb Soni
Hi Everyone, Hope you guys are doing well. I'm trying to build common_android_kernel-3.10 on mini2440(x35). Did configuration by merging three configuration (mini2440_defconfig, android-base.cfg and config_mini2440_x35) files using scripts/kconfig/merge_config.sh. Got zImage successfully, without any errors. PROBLEM: But the problem is not able to see kernel messages on my pc. I'm using ttyUSB0 serial cable with minicom tool. Did changes changes on default kernel command line options as console=ttySAC0,115200. Not able to find the solution. I would be thankful if anyone helps me.
