Hi all, I have just received the NanoPC-T1 ( which should be Tiny4412 shouldn't it ). I opened the box, connected the USB keyboard, the HDMI and the power and I get a red led on. However no output to the HDMI at all ( TV stays in black screen and HDMI input icon showing no signal ). I checked the manual ( "NanoPC-T1 Manual 2014-01-24" on this site ) and it says nothing about a first time boot. I connected it via USB to my Linux box and I get the following from dmesg: [ 5167.108215] usb 2-2: new high-speed USB device number 4 using ehci-pci [ 5167.241896] usb 2-2: New USB device found, idVendor=18d1, idProduct=d011 [ 5167.241909] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=4 [ 5167.241917] usb 2-2: Product: Full Android on TINY4412 [ 5167.241925] usb 2-2: Manufacturer: FriendlyARM (www.arm9.net) [ 5167.241932] usb 2-2: SerialNumber: 0123456789ABCDEF Isn't Android on this system supposed to support HDMI output? Please help me get it as I do not have any alternative to get control to the device. Thanks, Svetlin
No HDMI output from a new NanoPC-T1
Try changing the HDMI to: LCD-Type = HDMI720p60 it's normally set for 1080 and maybe your TV cannot handle 1080p Phil
Thanks Phil_in_China, I suppose this setting is in FriendlyARM.ini, isn't it? I could not find this file in my filesystem. I installed the following Linux as Android was not showing any HDMI output: Ubuntu-1308(Support HDMI and LCD) ( as on the page: http://nanopc.org/NanoPC-T1_Feature.html ) I checked /images in the Linux partition and /images is empty. Is the images folder supposed to be in the Linux partition on the SD card? I see there is also another partition marked as Windows-fat but the filesystem must not be vfat as I could not mount it on my Linux Mint. Can somebody send me the full content of the correct FriendlyARM.ini for Ubuntu-1308 and where exactly (which partition and which folder) should I copy it, please? Also my TV is Full HD and it works perfectly well with Raspberry PI. Thanks, Svetlin
For ubuntu you set it from command line. See: http://www.nanopc.org/NanoPC-T1_Development.html#tag
