I have faced strange problem. case 1) ping 6410 to PC result : failed case 2) PC to 6410 -> 6410 to PC result : success case 3) PC1 to 6410 (continuously) 6410 to PC2 result : before 6410 send ping, PC1`s ping works well as soon as send ping, PC1 says 'Unreachable' I uploaded test file about ping log. Not only on ping work, also doesn`t work on other network like socket or wget. If 6410 send socket first, it stops. If pc send first, works well. I have setup apache so if using "wget http://(PC IP)" download index.html. But it only works after PC send ping to 6410. I have searched forum but I cannot find similar issue. If anyone knows about this, give me a answer. Thanks.
Error when using network (tiny6410)
I checked using Wireshark. When ping works well, I checked it on wireshark. When 6410 downed, wireshark showed no data transfered. Change other router and tested but still has same problem.
