Mini6410, compiling opencv and libjpeg
bianchi
Guys,
I tried to compile an opencv code but got the issue with libjpeg,
it's already compiled in Cmake but I can't find the library on
/Build/lib/...
the cmake on libjpeg :
Scanning dependencies of target libjpeg
[ 69%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jcmaster.o
[ 69%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jerror.o
[ 70%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jmemansi.o
[ 70%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jidctint.o
[ 70%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jdcoefct.o
[ 70%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jcomapi.o
[ 70%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jquant2.o
[ 70%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jutils.o
[ 71%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jcmainct.o
/root/Download/OpenCV-2.1.0/3rdparty/libjpeg/jcmainct.c: In function
'start_pass_main':
/root/Download/OpenCV-2.1.0/3rdparty/libjpeg/jcmainct.c:71:15: warning:
'main' is usually a function
'process_data_simple_main':
/root/Download/OpenCV-2.1.0/3rdparty/libjpeg/jcmainct.c:117:15: warning:
'jinit_c_main_controller':
/root/Download/OpenCV-2.1.0/3rdparty/libjpeg/jcmainct.c:247:15: warning:
[ 71%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jfdctint.o
[ 71%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/transupp.o
/root/Download/OpenCV-2.1.0/3rdparty/libjpeg/transupp.c: In function
'jtransform_adjust_parameters':
/root/Download/OpenCV-2.1.0/3rdparty/libjpeg/transupp.c:1305:3: warning:
enumeration value 'JXFORM_NONE' not handled in switch
enumeration value 'JXFORM_FLIP_H' not handled in switch
enumeration value 'JXFORM_FLIP_V' not handled in switch
enumeration value 'JXFORM_ROT_180' not handled in switch
'jtransform_perfect_transform':
/root/Download/OpenCV-2.1.0/3rdparty/libjpeg/transupp.c:1431:3: warning:
enumeration value 'JXFORM_TRANSPOSE' not handled in switch
[ 71%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jidctred.o
[ 71%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jcprepct.o
[ 71%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jdapistd.o
[ 72%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jdcolor.o
[ 72%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jdmerge.o
[ 72%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jfdctflt.o
[ 72%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jcapistd.o
[ 72%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jcsample.o
[ 72%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jchuff.o
[ 72%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jdapimin.o
[ 73%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jccoefct.o
[ 73%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jcparam.o
[ 73%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jcdctmgr.o
[ 73%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jdmainct.o
/root/Download/OpenCV-2.1.0/3rdparty/libjpeg/jdmainct.c: In function
'alloc_funny_pointers':
/root/Download/OpenCV-2.1.0/3rdparty/libjpeg/jdmainct.c:162:15: warning:
'make_funny_pointers':
/root/Download/OpenCV-2.1.0/3rdparty/libjpeg/jdmainct.c:203:15: warning:
'set_wraparound_pointers':
/root/Download/OpenCV-2.1.0/3rdparty/libjpeg/jdmainct.c:243:15: warning:
'set_bottom_pointers':
/root/Download/OpenCV-2.1.0/3rdparty/libjpeg/jdmainct.c:272:15: warning:
'start_pass_main':
/root/Download/OpenCV-2.1.0/3rdparty/libjpeg/jdmainct.c:309:15: warning:
/root/Download/OpenCV-2.1.0/3rdparty/libjpeg/jdmainct.c:349:15: warning:
'process_data_context_main':
/root/Download/OpenCV-2.1.0/3rdparty/libjpeg/jdmainct.c:389:15: warning:
'jinit_d_main_controller':
/root/Download/OpenCV-2.1.0/3rdparty/libjpeg/jdmainct.c:478:15: warning:
[ 73%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jdphuff.o
[ 73%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jdsample.o
[ 74%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jdmaster.o
[ 74%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jdhuff.o
[ 74%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jdatadst.o
[ 74%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jcinit.o
[ 74%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jidctflt.o
[ 74%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jdinput.o
[ 75%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jidctfst.o
[ 75%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jdatasrc.o
[ 75%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jmemmgr.o
[ 75%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jccolor.o
[ 75%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jddctmgr.o
[ 75%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jdtrans.o
[ 76%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jcmarker.o
[ 76%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jdpostct.o
[ 76%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jcphuff.o
[ 76%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jdmarker.o
[ 76%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jfdctfst.o
[ 76%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jcapimin.o
[ 76%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jquant1.o
[ 77%] Building C object 3rdparty/libjpeg/CMakeFiles/libjpeg.dir/jctrans.o
Linking C static library ../lib/liblibjpeg.a
[ 77%] Built target libjpeg
compiling test.c :
[root@localhost opencv]# arm-linux-g++
-I/root/Download/OpenCV-2.1.0/include/opencv
-L/root/Download/OpenCV-2.1.0/Build/lib
-L/path/to/opencv_folder/build/3rdparty/lib test.c -o test -lcv -lcxcore
-lcvaux -lhighgui -lml -llibjpeg -llibpng -lpthread -lz -lopencv_lapack
-lrt
/opt/FriendlyARM/toolschain/4.5.1/lib/gcc/arm-none-linux-gnueabi/4.5.1/../../../
../arm-none-linux-gnueabi/bin/ld:
cannot find -llibjpeg
collect2: ld returned 1 exit status
any ideas ?
thanks
