Hello! Did anybody install Ubuntu on 4412 board? NanoPC images from http://forum.nanopc.org/viewtopic.php?f=3&t=851 with qtopia works well, but ubuntu images don't.
Ubuntu linux for 4412 - is it real?
Yes. I am using the Ubuntu image on a super4412 board. The image works, but without kernel sources, can't do what I want to do. Hoping they release the source soon. The steps I used: Used the SD-Card image to boot from SD. The instructions say to use the tool that is included in the rootfs to write the image to flash, but that method always failed.(something different between super4414 and nanoPC???) So instead I extracted the rootfs from the SD-image, repackaged it with the img builder utility and then used minitools to write it to the flash. Now I can boot from flash without problem. Burning to flash takes close to 20 minutes and it seems very easy to corrupt the flash (when inside Ubuntu) which then requires a reflash. Also there were some permissioning issues once running Xubuntu from flash, but were easily overcome with a little googl'ing. I am using Xubuntu successfully with HDMI output but not yet working with the HD700 LCD. Hope this give you some hope.
Thanks for your answer! Explain please your step: after you extract rootfs to empty dir which util you used? What is "img builder"?
The nanopc instructions say to run /UBUNTU_INSTALL/INSTALL when running ubuntu from SD, in order to burn it to emmc. With the super4412 this doesn't work... crashes the kernel with a message about 'scheduling while atomic' which I think means that one of the kernelmode drivers is calling 'sleep' while an atomic function is going on. I get this instability quite frequently trying use the nanopc ubuntu image on SD. frustrating that I can't figure out what is causing it. Anyway, to get the rootfs onto the emmc I took the rootfs.tar.gz that is present within /UBUNTU_INSTALL and extracted on my linux host, and then repackaged it using the android tools img builder utility (this is the format that minitools wants). Then I used minitools to burn the zimage, bootloader and this new rootfs image directly to emmc. Unfortunately it wasn't as stable as I needed (probably because it was sourced from the same rootfs as the SD image or maybe I introduced something unpleasant in my process.) Anyway I decided to build my own kernel based on the hardkernel sources. Messing around with that now. This is the command line I flash from minitools: root=/dev/mmcblk0p1 rootfstype=ext4 console=ttySAC0,115200n8 lcd=HD700 skipcali=y ctp=2 video=HDMI-A-1:1280x720M@60
Hi, I am using flashed ubuntu to tiny 4412, but its working fine using hdmi but my main concern is HD700 lcd. Is there any solution available so that my touch lcd (HD700) starts working. Can I recompile the linux kernel. Thanks alot
