NanoPC-T1 OSELAS or Yocto
bluscape
I've received my NanoPC. At this stage there is very little information
regarding custom Linux compilations. Seems like most boards using this
processor tend to use Android. I like my kernel and OS lean and fast.
Anyways.
I've been using Oselas on my Mini2440 and started compiling Yocto for my my
NanoPC.
Would it be possible to configure Oselas for the NanoPC (armv7)?
Enrico
I'm running a custom built angstrom distribution (based on yocto 1.6) with
kernel 3.14 on nanopc-t1 so yes, it's possible.
But looking at the (missing) answers here it seems that nanopc owners are
on their own...no bootloader sources, no kernel sources, no answers to the
most basic questions...
bluscape
Hi Enrico,
May I ask:
1.) What documentation did you use?
2.) What recipe did you use?
3.) What MACHINE type did you use?
4.) How did you create a RAM disk?
If possible, please give me as much info as possible to get Angstrom
running on my NanoPC.
Thank you
MC
bluscape
Hi Enrico,
I'm eager to hear from you!?
MC
bluscape
Well I've been looking all over and can't find anything compatible with the
NanoPC so I'm assuming you've created your own layer?
Juergen
Just a shot into the dark: The SoC is the main part, and anything else
around it is more or less not very important. So you should be happy to get
this machine up and running with a generic recent kernel configured for
this SoC. And I think, only the kernel is a critical component here. Not
the userland. For userland you can use some ARMv7 compiler to run your own
software. And that's why it is not important if you use Yocto, PTXdist or
Angstrom. First get your own kernel booting this machine and then you are
free to continue like you want.
bluscape
Hi Juergen,
Thank you for the reply.
That is exactly my problem, getting my own kernel to work. I do not have a
armv7 toolchain (or I do but read on).
When I started with my Mini2440, I battled for very long doing custom
compilations but then I found ptxdist and Oselas. That helped a lot but at
the same time I think it made me stupid and lazy.
To avoid having to spend weeks on getting nowhere and just to make things
simpler I'm looking at these distro's.
I'm scared of downloading a pre-compiled toolchain or even compiling my own
toolchain because I've experienced myself how it can go wrong.
Maybe I should give it a try again.......??
Juergen
Hi bluescape,
getting an ARMv7 toolchain should not be very difficult. But okay, it's my
point of view, because it is my daily job: I'm building one from our
toolchain bundle and then I'm ready to work with it.
Maybe you will be happy with one of the ready-to-be-use distros. Try to use
embedian or similar. But most of the time embedded people need more
specific things than a generic distro can provide. At least the kernel is
this very specific thing one needs first. That is why binary distros drive
me crazy. For my development host as well. My development host bases on
"Linux from Scratch". Okay, that is the hard way. But you can learn a lot
*how* things are work. After these lessons tools like Yocto or PTXdist are
just tools that help you to collect and compile your own software. Nothing
more. And these tools are really nothing more.
*You* are still the important part, who assembles all the small details,
not the machine, not the tool.
Happy hacking
bluscape
Ok, I've managed to compile a working kernel. Now busy with busybox and
then the painful part, getting Qt5 working. Will keep you posted.
fatalsaint
Bluscape or Enrico,
What was the method you used to get your custom working kernel?
I've been able to cross-compile a bare bones rootfs that almost works
(still working with kinks) with the help of the buildroot utility, if I
supply the released QT kernel (zImage) file for superboot and my own rootfs
then the device boots, but has a few errors I need to work around.
However, I have been completely unsuccessful at getting a custom zImage
(tried 3.13, 3.14, and 3.15 rc2) to boot the device.  After flashing with
Superboot and resetting it simply says "Booting to eMMC" over serial and
never launches the kernel (no error messages either).
I must be missing something simple.. any help appreciated.
bluscape
Documentation:
http://processors.wiki.ti.com/index.php/Creating_a_Root_File_System_for_...
http://minidevs.googlecode.com/files/Tiny210-Mini210%20System%20developm...
Sources:
http://kanebebe.dip.jp/download/Cortex-A9-4412-DVD/
Using the toolchain and kernel from the Sources link. Following TI
documentation to compile a custom FS.
Cheers
MC
fatalsaint
Ok, thanks Bluscape.
I actually have that linux-3.5 source but I was hoping to get a more recent
kernel version to work.  Enrico had mentioned he was working on a 3.14.
Thanks for the extra documentation, I will definitely go through it.  Also,
I appreciate the reply!  A lot of the NanoPC-T1 threads around here seem to
die with open questions.
bluscape
Just download the 3.14 kernel and copy the config file from the 3.5 kernel
to the 3.14 kernel. The config file will not have all the configurations
for the 3.14 kernel but the majority will be the same (you might need to
tweak it). Then compile it.
fatalsaint
Yup, that's what I've done, several times.  I'm sure my zImage is good..
but for some reason superboot won't boot it but will boot the qt zImage.
I verified all the right Tiny4412 stuff was selected before compiling too.
BTW: Thanks again for the Root FS document.. it helped me solve a few
issues on my rootfs.
bluscape
Ok, I might give it a go at some stage. Will let you know when I've done
that. Also keep me posted please. Thanks
bluscape
Last few things:
1.) Are you cross compiling? Meaning are you selecting the correct
toolchain (in the kernel config)?
2.) Do you compile with ARCH=arm (in the kernel make file)?
fatalsaint
Yeah, it's all within the same environment that I compile the rootfs which
works/executes flawlessly now that I setup the mdev stuff properly from
your link.
I have a minimal busybox rootfs with lighttpd, dropbear, python and qt
libraries.  Going to work on getting PyQT working on it as well.  Total
size so far just under 100MB.
Everything works great with the known good kernel.  That's my last missing
piece.
I will say though that I am not using the toolchain from the site.. I am
using my own toolchains.
I've tried following instructions from Embedded CLFS (manually), which used
the musl libc, and then getting lazy with buildroot (which is like your
Yocto I think) which uses uclibc.
These are my compiler settings within buildroot, I had similar for Embedded
CLFS:
BR2_ARCH="arm"
BR2_ENDIAN="LITTLE"
BR2_GCC_TARGET_ARCH="armv7-a"
BR2_GCC_TARGET_ABI="aapcs-linux"
BR2_GCC_TARGET_CPU="cortex-a9"
BR2_GCC_TARGET_FPU="vfpv3-d16"
BR2_GCC_TARGET_FLOAT_ABI="softfp"
BR2_GCC_TARGET_MODE="arm"
BR2_ARM_CPU_HAS_NEON=y
bluscape
Another useful article:
https://github.com/surajx/qemu-arm-linux/wiki/Compile-Linux,-BusyBox-for...
bluscape
Hi fatalsaint,
When BusyBox is compiled it generates a BIN file.
What type of image did you create from the BIN file and what tool did you
use?
Juergen
Did you honor the need for a device tree to configure your recent kernel at
runtime? Enable earlyprintk and debug in the kernel and the command line.
FatalSaint
Juergen,
Thanks for the tip on earlyprintk.  Enabling that and DEBUG I now see the
problem, but am not entirely sure how to fix it:
Superboot-4412 V1.6(20140317) by FriendlyARM
Booting from eMMC
Uncompressing Linux... done, booting the kernel.
Error: unrecognized/unsupported machine ID (r1 = 0x00001200).
Available machine support:
ID (hex)        NAME
ffffffff        Samsung Exynos4 (Flattened Device Tree)
Please check your kernel config and/or bootloader.
Research indicates this is a mismatch between the bootloader and the kernel
but I'm still trying to figure out where to add the machine ID to support
it.
Bluscape:
I'm not sure I understand your question?  When I compiled BusyBox on my own
I followed these instructions:
http://cross-lfs.org/view/clfs-embedded/arm/final-system/busybox.html
Which are very similar to the instructions in the link you provided for
creating a rootfs.  Basically just a make install to the target directory.
Now I'm having buildroot do it for me, but it's doing the same thing - just
make && make install to the target directory.
bluscape
Hi FatalSaint,
What bootloader are you using?
If you are using the pre-compiled bootloader then the problem is most
probably with your kernel compilation but there could still be a
discrepancy from the bootloader.
If you are using your own bootloader, have you tried booting with the
pre-compiled bootloader?
I'm sure you've done this but just check:
Kernel:
ARCH=arm make menuconfig
Sytem Type->ARM system type->SAMUNG EXYNOS
If it still fails, maybe probe /arch/arm
Juergen
FatalSaint,
the error message means your bootloader still expects a platform aware
kernel but the new kernel uses a devicetree for this purpose.
Update the bootloader to support device tree or enable the
CONFIG_ARM_APPENDED_DTB and append the devicetree manually to your kernel
(read the help of the ARM_APPENDED_DTB menu entry how to do so).
bluscape
Ahh! listen to the voice of experience!
FatalSaint
So, is there any guidance on compiling a bootloader that will work with the
NanoPC-T1?
I have tried the pre-compiled Superboot4412.bin, which is what gave the
above error, and have tried the U-Boot compatible image from the Ubuntu
release and it gives the same error.
I've tried compiling U-boot myself, but of course the NanoPC-T1 isn't
supported directly so I'm using board "smdkv310" (ODROID) which is also
based on the Exynos4 architecture.
It does not appear to be working, however.  I get no output with an SD card
flashed with my custom u-boot.bin binaries.
I will continue to look at CONFIG_ARM_APPENDED_DTB, but I had that already
enabled and setup in the kernel that I got that post from.
So, still haven't gotten a working kernel.
bluscape
Hi FatalSaint,
To deviate from the topic. Why do you want to use the latest kernel?
I've been down this road before. I wanted to use the latest kernel just
because it is the latest and for no other specific reason. I also had
difficulty getting it to work. Eventually I decided to stick to what was
working and never regret doing that. The kernel was slightly older but it
was doing its job and I didn't waste anymore time.
Actually I did eventually get it to work just to realize there was a
problem with that kernel version (Had some problems with the audio DMA).
Unless there is specific features in the latest kernel you would like to
use.
Note: You spend all that time just to have the latest kernel. Next month
there is another version, then what? Do you spend a lot of time getting
that to work too?
The kernel provided by friendlyarm is known to work with all the
peripherals on the NanoPC.
Maybe have a look at this article:
http://www.informit.com/articles/article.aspx?p=1647051&seqNum=5
It seems like you need two images, one for the kernel and one for the DTB.
In that case your bootloader must support this and your bootloader must
know from which address it must boot these two images. Or something like
that.
FatalSaint
Suffice to say, I believe we should be able to maintain and update our
devices as we choose.
For security, features, patches, whatever.  I don't suspect they will be
releasing regular kernel updates and if I decide to use this board as part
of a real project we need to be able to maintain updates.
It's a great little board, it'd just make it that much better if we could
get some documentation on building our own bootloader/kernel without
needing to reverse engineer it.
FatalSaint
Well, I got it to work by compiling the appropriate dts with the zImage in
the kernel.
There was a .dts for me already in the 3.14 kernel tree
(exynos4412-tiny4412).
It now boots the kernel but I'm working through finding all the drivers for
all the pieces on board now.
Thanks for all the help Juergen and bluscape.
bluscape
Ahh! That is great news! Well done!
I got busy with other things again.
Will see when do I get a chance to work on the NanoPC again.
May I ask for your email to share info?
Cheers
FatalSaint
So far my hurdle is finding the right driver for the onboard eMMC.  I have
everything in the MMC/SD options enabled and yet the kernel still panics on
boot unable to mount the rootfs.
I don't want to give a full address on a publicly scrapable board but my
gmail is fsalucard.
bluscape
Do you support the correct file systems (ext2, ext3, etc.)? Is your
bootloader booting from the correct block?
FatalSaint
Yes, it just doesn't see the onboard eMMC.  If I leave the SD card I flash
it from in, it identifies that as mmcbkl0 and tries to mount it there,
which obviously doesn't work.
If I take that out, it just fails to mount root filesystem and says
"available partitions:" with nothing listed.
This whole eMMC/SD business ... maybe the Ordriod U3 forum
http://forum.odroid.com/index.php
might hold clues as there seems to be quite a bit of similar traffic on
that site.
And the hardware is quite similar.
FatalSaint
Davef,
Thanks for the tip.  I rebuilt my dtb in my kernel with the
exynos4412_odroidx config instead of the tiny4412, and now my eMMC/SD card
is discovered.
It mounts the rootfs now.. but kernel panics shortly after lol.
Not much in way of useful information either.. So I'll keep working at it.
What is the first error message?
FatalSaint
There isn't really an error message.  It just panics.
[    5.160000] mmcblk0rpmb: mmc1:0001 M8G1WA partition 3 128 KiB
[    5.165000] ALSA device list:
[    5.165000]   No soundcards found.
[    5.170000]  mmcblk0: p1
[    5.175000] mfc-power-domain: Power-off latency exceeded, new value
361833 ns
[    5.180000]  mmcblk0boot1: unknown partition table
[    5.185000]  mmcblk0boot0: unknown partition table
[    5.195000] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data
mode. Opts: (null)
[    5.195000] VFS: Mounted root (ext4 filesystem) readonly on device
179:1.
[    5.205000] devtmpfs: mounted
[    5.210000] Freeing unused kernel memory: 332K (c0931000 - c0984000)
[    5.230000] Unhandled fault: imprecise external abort (0xc06) at
0xb6fed008
[    5.250000] Kernel panic - not syncing: Attempted to kill init!
exitcode=0x00000007
[    5.250000]
[    5.250000] CPU: 0 PID: 1 Comm: linuxrc Not tainted 3.14.4-FriendlyARM
#3
[    5.250000] [<c001b3f4>] (unwind_backtrace) from [<c0017900>]
(show_stack+0x10/0x14)
[    5.250000] [<c0017900>] (show_stack) from [<c066a51c>]
(dump_stack+0x90/0xc8)
[    5.250000] [<c066a51c>] (dump_stack) from [<c0669b28>]
(panic+0xa4/0x1f0)
[    5.250000] [<c0669b28>] (panic) from [<c0029f10>]
(complete_and_exit+0x0/0x1c)
[    5.250000] [<c0029f10>] (complete_and_exit) from [<00000001>] (0x1)
[    5.250000] Rebooting in 5 seconds..
Juergen
There is an error message:
0xb6fed008
Your kernel tries to start the userland init process and fails. How did you
generate your root filesystem?
seware
Juergen,
How can you tell it's failing in the init process? The whole problem with
imprecise aborts is that they are imprecise... that is, the fault is not
detected until after (sometimes well after) the faulting instruction has
been processed... The call stack that's shown is just what happens to be
upstream of the PC at the time the fault was detected but is not likely to
be what caused the fault when it is "imprecise". I thought the only way to
zero in on imprecise faults was kernel debugging. If you have other magic
beans, please do tell... I am dealing with imprecise faults of my own (but
only after the system has been up and running for awhile).  Aggravating.
FatalSaint
Juergen,
I appreciate the info but instead of me trying to explain how I'm building
the rootfs can you explain the "proper" way to do it?
This same rootfs works fine using the kernel released from the QT distro,
so I'm not sure why it would be the rootfs fault that this kernel is
panicing.
Juergen
I often saw such kind of error message. And always the userland/root
filesystem was broken somehow. Sometimes due to a wrong toolchain,
sometimes due to missing libraries, sometime due to wrong ABI, wrong math
and so on...
Yury
Hello!
I have a similar task: kernel 3.15 on NanoPC. I have built kernel image +
dts information, and now have halt after: "Uncompressing Linux... done,
booting the kernel.".
Can anyone give me any ideas?
Leo
I have done some work on the nanopc-t1 trying to make an *useable* mfc
kernel.
Fistly i have noticed that the nanopc kernel is based of odroid 3.8
sources, i tried to hack around a new odroid version, but there's still
work to be done, regulators stuff:
https://github.com/leojrfs/linux-nanopc-t1
I have a SD & emmc booting device tree file for mainline linux here:
https://github.com/leojrfs/nanopct1-dts
I wont be on this forums, so, create issues on the respective github repos.
