hello every body I have a sumsung s3c2440Al - 40 and its os is win ce. I would like to install linux on it via DNW. I don't know which nand flash I have 64 or 128 the bios list options is ##### ## BIOS for ## ##### Press Space key to Download Mode ! ##### Boot for Nor Flash Main Menu ##### [1] Download u-boot or STEPLDR.nb1 or other bootloader to Nand Flash [2] Download Eboot to Nand Flash [3] Download Linux Kernel to Nand Flash [5] Download CRAMFS image to Nand Flash [6] Download YAFFS image to Nand Flash [7] Download Program (uCOS-II or EM2440_Test) to SDRAM and Run it [8] Boot the system [9] Format the Nand Flash [0] Set the boot parameters [a] Download User Program (eg: uCOS-II or EM2440_Test) [b] Download LOGO Picture (.bin) to Nand Flash [l] Set LCD Parameters [o] Download u-boot to Nor Flash [r] Reboot u-boot [q] quit from menu Enter your selection: 9 I select Format nand and I recieved ##### Erase Nand Menu ##### [1] Nand scrub - really clean NAND erasing bad blocks (UNSAFE) [2] Nand earse - clean NAND eraseing [q] Return main Menu I select 1 for nand dcrub then I select 1 and download supervivi64.bin 3 and download zImage_2.6.30.4_W43_64MB.bin 6 and download root_qtopia_2.2.0_2.6.30.4_64MB.bin but at the end I select 8 for booting the system and i have these error Failed to execute /linuxrc. Attempting defaults... Kernel panic - not syncing: No init found. Try passing init= option to kernel. Backtrace: [<c0046fd4>] (dump_backtrace+0x0/0x10c) from [<c02be40c>] (dump_stack+0x18/0x1c) r7:00000000 r6:c03c9da0 r5:c03c9760 r4:c03a2248 [<c02be3f4>] (dump_stack+0x0/0x1c) from [<c02be45c>] (panic+0x4c/0x124) [<c02be410>] (panic+0x0/0x124) from [<c00424f0>] (init_post+0xec/0x178) r3:00000000 r2:c384ad00 r1:c03fd000 r0:c034befc [<c0042404>] (init_post+0x0/0x178) from [<c000847c>] (kernel_init+0xcc/0xf4) r5:c001d6b0 r4:c001da14 [<c00083b0>] (kernel_init+0x0/0xf4) from [<c0057f30>] (do_exit+0x0/0x620) r7:00000000 r6:00000000 r5:00000000 r4:00000000 any help will be appreciated
install linux error
http://www.friendlyarm.net/downloads and under datsheets you will see the different flash types listed. Read the number of the top of the flash chip and you are off and running.
I found size of nand flash .it is 64M nand flash. I did the following things Nand scrub - really clean NAND erasing bad blocks (UNSAFE) supervivi64.bin zImage_2.6.30.4_W43_64MB.bin root_qtopia_2.2.0_2.6.30.4_64MB.bin remove usb cable and then boot the system linux was installed but when i powered off and poweredd on in nand flash,the screen was black
You are sure is it a w43 screen? You really want to connect the mini2440 to your host PC and capture the bootup messages. Use the RS232 cable supplied by FriendlyArm and run minicom on your host (115200, 8N1)
Sorry, I see you already have seen the error. > Failed to execute /linuxrc Search for that on this site, I am sure it is a fairly common problem.
boot linux from nand flash have problem I install linux and it boot in nor flash but in nand flash linux don't load and here it's messages Warning: this binary is not compressed linux kernel image zImage magic = 0xffffffff Setup linux parameters at 0x30000100 linux command line is: "noinitrd root=/dev/mtdblock3 init=/linuxrc console=ttySAC0" MACH_TYPE = 1999 NOW, Booting Linux......
I just went to the downloads page to check a few things and I see there are no versions of Qtopia there ... any more. I reason I checked is because I have never seen any of the files you refer to. 2.6.30 looks odd as I thought all the FriendlyArm distros were 2.6.32 based. Are you sure there are .bin extensions on the files? Where did you get those files from? Put zimage magic in the forum search. Good luck!
hello and thanks for your response I found these files on DVD. but I did't find any more in download page . Is there a link on download page for linux kernel and yaff also In nor flash linux will be boot but that error is for nand flash.
Software -> ARM9 -> Linux 2.6.32.2 2011-04-13 is the kernel But I see the yaffs2 root file system files are gone now, as well. Wait a minute ... go down to the bottom of the downloads page and log in to the FTP server, I think everything is now in there.
hello Davef and thank you for kindly response Linux 2.6.32.2 2011-04-13 in Software->ARM9 is a tar.gz file not a .bin file and DNW cannot download it Is there any way for downloading bootloader and linux kernel and file system for mini2440.
Linux .tar.gz You need to extract it on your Linux host machine. Sort of like a .zip file on a Windows machine. This file will get your the patched Linux source for the mini2440. I don't think you are ready to compile your own kernel. > Is there any way for downloading bootloader and linux kernel and file > system for mini2440. Well, there are lots of ways, but first ... didn't you get a CD with all these files on it? Failing that, on the FTP server there should be images that you can just download using DNW to your mini2440.
Hello and thanks the images that i found in DVD are : rootfs_64M.bin rootfs_256MB.bin u-boot_A70.bin u-boot_W35.bin root_2.6.13_condense_64MB.bin root_2.6.13_qt_mouse_64MB.bin root_2.6.13_qt_tp_64MB.bin root_qtopia_2.2.0_2.6.30.4_64MB.bin root_qtopia_2.2.0_2.6.30.4_256MB.bin and I downloaded supervivi64 from download page. LCD is KD43G7-40NM-82 NAND flash is 64 MB I couldn't find any images file in ftp server and i do'nt know when linux can boot in nor flash but not in nand flash ,what is wrong
The ftp server contents look quite different this time. Last time I looked was when they actually offered that service, a few years ago. 2.6.13 I think was when they first introduced the product. I got involved at 2.6.32.2 I ditched FriendlyArm distros about two years and put my learning effort into the Pengutronix BSP. One major plus with Pengutronix is that there is really good support for this free BSP. Even I might be of more help :) Booting from NOR and Flash. From memory Supervivi bootloader goes into NOR but also there is something else that gets loaded into Flash, so that you can boot from there. Read through this procedure http://forrestbao.blogspot.co.nz/2008/01/deploying-embedded-linux-to-sam... and maybe you will see that he uses Supervivi in NOR to load u-boot.bin (another bootloader)into RAM then into FLASH. Then the kernel and root filesystem are loaded into flash. And away you go. Are you following a written tutorial or procedure? Also, I would suggest getting more up-date files. Sorry, I don't know where to get them.
Hello Davef thank you very much indeed for your help I download u-boot_W43.bin instead of suppervivi64.bin zImage__W43_64MB instead of zImage_2.6.30.4_W43_64MB.bin and root_qtopia_2.2.0_2.6.30.4_64MB.bin. linux boot in Nand flash successfully thank you for everything
Good going! Just curious you said: > zImage__W43_64MB instead of zImage_2.6.30.4_W43_64MB.bin specifically the first file zImage__W43_64MB, is it not a uImage?
> it is 2.6.30.4-EmbedSky Ah, you don't have a FriendlyAm mini2440. I didn't pick that up when you said you had a s3c2440Al - 40 There could be some differences as you have two different groups of people patching the mainline kernel for their particular boards. Stick with whatever came with the dev board until you run into a problem. A few years ago uboot would only load uImages, but with more recent versions it will load zImages. Yes, uImage is a Linux kernel with a different header format, or different compression or ? compared with zImage. Be aware there have been many changes since 2.6.30.4 but for a learning exercise or doing most stuff it should be OK. I doubt if EmbedSky keep up to-date, likewise FriendlyArm. We still use 2.6.20 in a product, you just need people who are good at patching old kernels! Pengutronix are up 3.14
