Activate Internet on Friendly ARM
Rohit Malve
Hi everyone,
 My friendly ARM mini2440 is connected to LAN Network which is working
fine.
 But I am not able to browse a website through ARM board.So tell me the
steps to Turn On the internet on ARM board mini2440.
I am using linux OS.
You need a web browser.  I am not aware of a reasonably capable web browser
you can run in Linux on the mini2440.  I have cross-compile Arora and use a
Qt demos/fancybrowser example as a local web browser.  But they don't hack
it for general web browsing.
Good luck!
Rohit Malve
Hi davef,thanx for immediate responce.
   I am not even getting reply for command ping "www.google.com".Is there
any setting which i need to do to use internet on mini2440.
  I am new to this stuff so maybe I am asking stupid things,please
co-operate.
Try pinging 8.8.8.8
You will need an entry in /etc/resolv.conf for a nameserver
Rohit Malve
Hi davef,
Getting reply for command ping 8.8.8.8
Rohit Malve
In /etc/resolv.conf there is entry for nameserver.Still facing the same
problem.
Is the nameserver in your resolv.conf your local device that is going to do
the name translation?
You could also search for using 8.8.8.8 and 8.8.4.4. (I think) as external
nameservers
Juergen
You need a "/etc/nsswitch.conf" to tell the basic C library how to resolve
names to IPs. And if you list 'dns' in its 'host' line you also need the
"/etc/resolv.conf". And you need the shared libraries from the basic C
library installed on your target to do the work (libresolv.so,
libnss_compat.so,  libnss_dns.so and so on).
If you have the "strace" tool available on your target you can monitor your
ping command how it tries to convert your "www.google.com" to an IP (and
why it fails).
sundeep
Hi Rohit
U once check the DNS of ur /etc/eth0-setting file, the DNS IP should match
your router configuration i.e normally routers contain IP addres like
192.168.0.1 or 192.168.1.1 (will be written on ur router box). According to
  it change the eth0 setting file. Then u can able to access the internet.
For any further u can ping me, k.sundeep2007 at gmail
