Make this application
camak
hello guys,
anyone know how to make this app? what kind of gsm modem did they use in
this project?
http://www.ijera.com/papers/Vol2_issue1/EK21863869.pdf
thanks
I try asking the authors.
Sorry, I'd try ...
camak
thanks davef, how about this one guys? any idea?
http://www.youtube.com/watch?v=fP_m9JE6PEA
About all I can see is that both SMS modules looks professionally made.
Maybe Google would help here.
I am interested in what he has done, but he seems slow in responding to
comments.
Google GSM modem module and look at the images
http://alltechforum.com/ but you have to search through the site to find
it.
Error, not SMS but GSM
http://alltechforum.com/components.php#?id=71#
Datasheet does not look helpful
Another issue is, I don't see any kernel configuration happening in the
first article.  Having had a go at PPP myself I would expect a special
kernel config file.
Then you really want the source code of the applications as well.
Unless someone has wrapped all the required work up into a tutorial, it is
going to be a BIG difficult task.
Good luck!
http://rndhax.blogspot.co.nz/2010/03/friendlyarm-mini2440-huawei-e160-hs...
Might help.
camak
Thanks davef, do you know how to use the serial port of mini2440 in linux
qtopia?
No, have look aroung these sites
http://mini2440vietnam.blogspot.co.nz/2011/04/upgrade-qt462-in-mini2440....
http://www.sereno-labs.com/
and search this forum for "domdom"
And, of course "qt mini2440 serial"
http://www.embedded4fun.com/serial-port-interfacing-in-qt/
sandy
Hi Camak
Greetings
will provide support for this project , keypad and application is also
readily available. pls contact k.sundeep2007@gmail.com
