Problem in configuring kernel
Satish778
Attachment: screen shot of config kernel.png (169.37 KB)
This is Satish. I started working on Friendly arm Nano2410 SDK40
(SBC2410III)board. While in the installation procedure i got struck in
configure kernel. i attached the screen shot of which i got error while
configuring. Let Check it the screen shot so that you may get an idea where
i going wrong.please suggest me the proper procedure for configuring it.
Thank You in advance.
Srikanth
Hi Satish,
As per the attachment, while doing the make all , it is looking for the
path mentioned in the file....
In the mentioned file where ur are compiling the source using the
cross-compile tool chain gcc-arm-linux. but is not found in ur case.
For testing purpose, u can go to that path, and check with cross tool chain
available or not.
and second compile with only gcc compiler instead of arm-gcc-linux
compiler....
Thanks,
Srikanth.
