Hi I did install linux step by step with according to "linux user manual" but I got stuck at 2.1.1 step: Compile the uboot for booting from Nand Flash I got this error and after lots of searching I got nothing :( for dir in tools examples post post/cpu ; do make -C $dir _depend ; done make[1]: Entering directory `/opt/EmbedSky/u-boot-1.1.6-TQ6410/tools' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/opt/EmbedSky/u-boot-1.1.6-TQ6410/tools' make[1]: Entering directory `/opt/EmbedSky/u-boot-1.1.6-TQ6410/examples' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/opt/EmbedSky/u-boot-1.1.6-TQ6410/examples' make[1]: Entering directory `/opt/EmbedSky/u-boot-1.1.6-TQ6410/post' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/opt/EmbedSky/u-boot-1.1.6-TQ6410/post' make[1]: Entering directory `/opt/EmbedSky/u-boot-1.1.6-TQ6410/post/cpu' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/opt/EmbedSky/u-boot-1.1.6-TQ6410/post/cpu' make -C tools all make[1]: Entering directory `/opt/EmbedSky/u-boot-1.1.6-TQ6410/tools' gcc -Wall -pedantic -idirafter /opt/EmbedSky/u-boot-1.1.6-TQ6410/include -idirafter /opt/EmbedSky/u-boot-1.1.6-TQ6410/include2 -idirafter /opt/EmbedSky/u-boot-1.1.6-TQ6410/include -DTEXT_BASE=0xc7e00000 -DUSE_HOSTCC -O -c -o img2srec.o img2srec.c make[1]: gcc: Command not found make[1]: *** [img2srec.o] Error 127 make[1]: Leaving directory `/opt/EmbedSky/u-boot-1.1.6-TQ6410/tools' make: *** [tools] Error 2
Error while making u-boot_nand.bin for mini6410
"Nothing to be done" suggests to me that maybe this compilation has already been done. I would be more concerned about "gcc: Command not found" Which cross-compiler are you using and where is it located?
Tnx for your reply Im using gcc version 4.3.3 (Sourcery G++ Lite 2009q1-176), I check it, it is successfully installed. Ad its location is on /opt/EmbedSky/4.3.3
And you have a path to it in your environment variables. And you have checked the version from the command line?
I make a path with this instruction: export PATH=$PATH:/opt/EmbedSky/4.3.3/bin and then check from command line and took a snapshot which is attached here.
