Hello, I have create my own root file system its work well.but i am added the Qt lib inside the rootfs and create image its size is is 102480576kb inserted on board show error Length of file is too big :102480576 > 64085884. How to solve this problem
Error in Rootfs
Put your rootfs on a SDcard. I managed to run Arora under Qt on a 64M machine by using swap. Think you will find it at: http://billforums.station51.net/index.php?sid=8977c4091a0b77b4ff19995fbe...
Not boot using SD card, your kernel is still on the target. I can't search around for it now, but I'd start in the Qt section. Good luck. CU tmw if you haven't found it
Hi Sushant, Can u post the procedure to create a new rootfs using qtopia image so i that i want to run the applications from touch screen, by creating a icon. It will be very helful if so,u can also mail me to k.sundeep2007@gmail.com Thanks for the help
