I/O Controller...
Girish
      I'm looking for a I/O Module (Preferably ARM based) with 4-8 Digital
Inputs, 4-8 Digital (Relay - 240V/5A) Outputs, with an Ethernet port, RTC
with battery, RS485 port with 64-128MB RAM and 64-128MB Flash. The device
be operated on a Linux (Minimal version) based operating system. And also
require the cross-compiler (GNU-GCC is fine) to compile applications for
the board.
        I would like to know if you have any such device which suits my
requirements, what will be the cost of the board and timeframe for
availability of same.
Thanks & Regards,
     Girish
sean_h
Hi
If you Google netiom you will find a network based IO / relay card. Use a
separate Linux platform for RTC etc and then simply communicate with the
netiom card.
Regards
Sean
