can't install android on mini 2440
david123456
Hello
I have follow this guide
and done one-by-one what he said
but after I do boot
this is what I get
Enter your selection: b
Copy linux kernel from 0x00060000 to 0x30008000, size = 0x00500000 ... done
zImage magic = 0x016f2818
Setup linux parameters at 0x30000100
linux command line is: "noinitrd root=/dev/mtdblock3 init=/linuxrc
console=ttySAC0"
MACH_TYPE = 1999
NOW, Booting Linux......
Uncompressing
done, booting the kernel.
Linux version 2.6.27 (root@phuc-laptop) (gcc version 4.3.2 (Sourcery G++
Lite 2008q3-72) ) #1 PREEMPT Wed May 18 00:05:41 ICT 2011
Machine: FriendlyARM Mini2440 development board
ATAG_INITRD is deprecated; please update your bootloader.
CPU S3C2440A (id 0x32440001)
MM: CPU does not support supersection mapping for 0x55000000000 at
0xf0d00000
CLOCK: Slowst, MPLL on, UPLL on
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
Kernel command line: noinitrd root=/dev/mtdblock3 init=/linuxrc
console=ttySAC0
irq: clearing subpending status 00000003
PID hash table entries: 256 (order: 8, 1024 bytes)
timer tcon=00000000, tcnt a4ca, tcfg 00000200,00000000, usec 00001e57
console [ttySAC0] enabled
Memory: 64MB = 64MB total
Memory: 60188KB available (3896K code, 636K data, 116K init)
SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
net_namespace: 288 bytes
S3C2440: IRQ Support
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c4800000, irq 33
DMA channel 1 at c480004nel 2 at c4800080, irq 35
DMA channel 3 at c48000c0, irq 36
SCSI subsystem initialized
TCP reno registered
NetWinder Floor V0.97 (double precision)
ashmem: initialized
NTFS driver 2.1.29 [Flags: R/W DEBUG].
yaffs May 18 2011 00:01:03 Installing.
msgmni has been set to 117
io scheduler noop registered (default)
Console: switching to colour frame buffer device 30x20
adc  initialized
input: buttons as /class/input/input0
buttons  initialized
leds  initialized
s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
brd: module loaded
loop: module loaded
nbd: registered device at major 43
logger: created 64K log 'log_main'
logger: created 256K log 'log_events'
logger: created 64K log 'log_radio'
dm9000 Ethernet Driver, V1.31
Now use the default MAC address: 08:90:90:90:90:90
eth0: dm9000e at c4804000,c4806004 IRQ 51 MAC: c3914934 (friendly-arm)
usbcore: regiface driver zd1211rw
usbcore: registered new interface driver zd1201
Linux video capture interface: v2.00
ovcamchip: v2.27 for Linux 2.6 : OV camera chip I2C driver
usbcore: registered new interface driver ov511
ov511: v1.64 for Linux 2.5 : ov511 USB Camera Driver
Driver 'sd' needs updating - please use bus_type methods
s3c2440-nand s3c2440-nand: Tacls=3, 29ns Twrph0=7 69ns, Twrph1=3 29ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V
8-bit)
NAND_ECC_NONE selected by board driver. This is not recommended !!
Scanning device for bad blocks
Bad eraseblock 1090 at 0x08840000
Creating 4 MTD partitions on "NAND 256MiB 3,3V 8-bit":
0x00000000-0x00060000 : "supervivi"
0x00060000-0x00260000 : "Kernel"
0x00260000-0x40260000 : "root"
mtd: partition "root" extends beyond the end of device "NAND 256MiB 3,3V
8-bit" -- size truncated to 0xfda0000
0x00000000-0x40000000 : "nand"
mtd: partition "nand" extends beyond the end of device "NAND 256MiB 3,3V
8-bit" -- size truncated to 0x10000000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcorenew interface driver usb-storage
USB Mass Storage support registered.
s3c2440-usbgadget s3c2440-usbgadget: S3C2440: increasing FIFO to 128 bytes
mice: PS/2 mouse device common for all mice
usbcore: registered new interface driver appletouch
input: s3c2410 TouchScreen as /class/input/input1
s3c2410 TouchScreen successfully loaded
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling
s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
i2c /dev entries driver
s3c2440-i2c s3c2440-i2c: slave address 0x10
s3c2440-i2c s3c2440-i2c: bus frequency set to 98 KHz
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
mapped channel 0 to 0
s3c2440-sdi s3c2440-sdi: powered down.
s3c2440-sdi s3c2440-sdi: initialisation done.
s3c2440-sdi s3c2440-sdi: running at 0kHz (requested: 0kHz).
s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz).
usbcore: registered new interface driver hiddev
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
UDA1341 audio driver initialized
failed to get memory region resouce
s3c2410-iis: probe of s3c2410-iis.0 failed with error -2
TCP cubic registered
s3c2410-rtc s3c2410-rtc: hctosys: invalid date/time
yaffs: dev is 32505859 name is "mtdblock3"
yaffs: passed flags ""
yaffs: Attempting MTD mount on 31.3, "mtdblock3"
yaffs: auto selecting yaffs2
block 1091 is bad
yaffs_read_super: isCheckpointed 0
VFS: Mounted root (yaffs filesystem).
Freeing init memory: 116K
load Image of Linux...Uncompressing
CPU: ARM920T [41129200] revision 0 (007177
0xf0d00000
console=ttySAC0
DMA channel 1 at34
DMA channel 2 at c4800080, irq 35
...stripped-down
