I'm trying to execute remote debugging from Qt creator 1.3.1. The debugger starts the application but I'm unable to set breakpoints. What I've done: 1.) Filesystem and application (compiled with debug flags) on my SD card. 2.) TestApp in /home on SD card 3.) gdb server running on my Mini2440: gdbserver 192.168.1.100:1000 ./TestApp -qws 4.) gdb server output: Process ./TestApp created; pid = 524 Listening on port 1000 5.) In Qt I've configured Tools->Options->Debugger->Gdb->Gdb location: /opt/OSELAS.Toolchain-2011.03.0/arm-v4t-linux-gnueabi/gcc-4.5.2-glibc-2.13-binut ils-2.21-kernel-2.6.36-sanitized/bin/arm-v4t-linux-gnueabi-gdbtui 6.) Qt build configuration set to debug 7.) Qt Run settings: Executable name: path-to-executable-on-development-machine Working directory: path-to-qt-project-files 8.) Started the debugger with Debug->Start Debugging->Start and Attach to Remote Application Host and port: 192.168.1.100:1000 Architecture: i386 At this point the debugger will start the application on the mini2440 but it seems like Qt does not enter debug mode and breakpoints does not work. Any ideas?
Qt remote debugging
Does the debugger know the path to your root filesystem? Seems you are using PTXdist. The debugger needs the path to the "platform-mini244/root-debug". This will enable it to get all debug info it needs for correct debugging (refer solib-absolute-prefix) Hope it helps
Hi Juergen, I have a couple of questions. 1.) Why gdbtui and not gdb? 2.) Do I need to run my Mini2440 from the debug file system too or should only the debugger work from there? 3.) Typically I would point the debugger to rootfs using: set solib-absolute-prefix platform-mini2440/root-debug, but now I'm debugging from Qt so I'm not sure how to proceed. I could explicitly set it from the terminal but Qt might overwrite it.
Hi bluescape, > 1.) Why gdbtui and not gdb? "gdbtui" is a text console based light weight debugging frontend. If the qtcreator acts as your frontend, you only need the "gdb" > 2.) Do I need to run my Mini2440 from the debug file system > too or should only the debugger work from there? The binaries in root/ and root-debug/ are the same. For executing these binaries it makes no difference. But the root-debug/ binaries still contain the debug symbols the debugger depends on. > 3.) Typically I would point the debugger to rootfs using: set > solib-absolute-prefix platform-mini2440/root-debug, but now > I'm debugging from Qt so I'm not sure how to proceed. I could > explicitly set it from the terminal but Qt might overwrite it You are just using a different frontend to "gdb". In the background still the same mechanism must be used. The important thing is to have your own Qt code linked against the libs in the root filesystem your Mini2440 "sees". The symbols the "gdb" collects at the host side must correspond to the binaries the Mini2440 uses. Only if they are in sync the gdb can do its job. Happy hacking.
