Hi, I bought a new S70 display for my 210s. But unfortunately the touch screen doesn't work right... I configured the board to S70 in the config file and flashed a new linux. When I start the new system, I see the calibration screen. After typing the five points (4 corners and center) the sequence starts again. This repeats for approx. 5 times. After that qtopia starts but the touch screen does not work... I tried to output the ts output to the console, but neither mouse or ts-if gave an output. Do you have any ideas how to solve this problem? Thanks and best regards Ozzy
210s: S70 touch doesn't work
Hi, after a few tries and installations I got the touch screen working; but not yet in my qt application... Is there any difference between the 1-wire ts and the "old" ts? The old ts worked fine with my compiled tslib (but on mini2440). Best regards Ozzy
Hi Andreas, it was working for some time (after a few fresh installations...). But since yesterday the ts strikes again. I can calibrate the touch screen and output the data of of touch by cat /dev/touchscreen... But when I start Qtopia, and touch the screen, the mouse cursor disappears and I can't click on a item. It's the same behavior as in my Qt application. Do you have any suggestions?
Hi, it seemed to be a problem of the touchscreen. I changed the display (ot the pcb), and now everything works fine... Best regards Ozzy
Hi Ozzy, If any issue u came across, then u can debug by doing the /proc/interrupts/ Check whether ur touchscreen driver is generating the interrupts to ur Processor, and the Processor is able to handle it. while doing or checking /proc/interrupts/ .......U need to touch the screen, so that it generates the interrupts, these interrupts are verified in the path /proc/interrupts/ with respective touch screen driver. Thanks, Srikanth.
