I have a Kingston, 2GB SD card. I've burn superboot on it, and it work well. Then I copy "images" folder with Linux images and configure FriendlyARM.ini file. But now it hang when I turn on the KIT (in SD card boot mode). The green led is off and there is no beep sound, the monitor is dark/or white (no text). Can you help me? Thanks!
Tiny6410 - Cannot run from SD card
I've format the SD card as FAT. And, this is the content of my configuration file: ------ #This line cannot be removed. by FriendlyARM(www.arm9.net) LCD-Mode = Yes LCD-Type = S70 CheckOneButton=No Action=Run OS= Linux VerifyNandWrite=No StatusType = Beeper | LED #################### Linux ##################### Linux-BootLoader = superboot-6410.bin Linux-Kernel = Linux/zImage Linux-CommandLine = root=ubi0:FriendlyARM-root ubi.mtd=2 rootfstype=ubifs init=/linuxrc console=ttySAC0,115200 Linux-RootFs-InstallImage = Linux/rootfs_qtopia_qt4-mlc2.ubi Linux-RootFs-RunImage = Linux/rootfs_qtopia_qt4.ext3
