FA_Config.exe touchscreen settings
hassan
Hi everyone,
I have a new BSP for mini 2440. Mini2440-CE6-Suite-1401. I was using
Mini2440-CE6-Suite-1115 with no error. Now with the latest BSP when Wince
booted FA_Config.exe appears for touchscreen settings. Problem is when
creating an image with kiosk mode i can not control Touchscreen settings.
Because my application prevents Fa_config.exe.
Any idea?
ferite
Hi hassan.
What I am doing is to edit the registry. Depending of the type of
controller you have in your touchscreen, you can set
HKEY_LOCAL_MACHINE\HARDWARE\DEVICEMAP\TOUCH\DriverName to touch.dll (the
old 4 wire) or touch_1wire.dll (1 wire of course). After that, you can call
TouchCalibrate(void). This is a WinCe functionality that launches the
calibration applet. Or even, if you know the optimal calibration values,
you can set them programatically in
HKEY_LOCAL_MACHINE\HARDWARE\DEVICEMAP\TOUCH\CalibrationData
