hi, On executing an Qt based Crosscompiled application on arm based board, containing touchscreen used -qt-mouse-linuxinput -plugin-mouse-tslib flags in configuring qmake also exported env on device export QWS_MOUSE_PROTO=Linuxinput:/dev/event0 on running the application, as the touch event occurs the following message is being displayed on console(as shown in attachment). Unknown mouseevent type=3 how to handle it?
Problem in run Qt app with touchscreen
Are you sure you have cross compiled your Qt against the same kernel headers and/or the same tslib headers than running on your target?
using same kernel and same tslib headers, ts_calibrate and ts_test applications are working fine but with qt facing the above problem.
You want to use tslib with your Qt library? If yes, you must use "QWS_MOUSE_PROTO=Tslib:/dev/input/event0" instead. And: are you sure, the "/dev/input/event0" is the touchscreen?
