Hello, I have sucessfully crosscompile the Qt & tslib lib and it install on mini2440 board. How to solve this problem.. ./fluidlauncher: /lib/libc.so.6: version `GLIBC_2.9' not found (required by /usr/local/qt/lib/libQtGui.so.4) ./fluidlauncher: /lib/libc.so.6: version `GLIBC_2.9' not found (required by /usr/local/qt/lib/libQtCore.so.4) Thanx in Advance
Problem in run Qt program
You are using a different libc revision to build your Qt-lib than running it. Both must be the same. Use a cross compiler und libc matching the root filesystem content on your Mini2440.
