Hi, Can some one tell me the driver for EEPROM AT24C0X path in kernel source code. Thanks.
Src path for at24c0x
Hi Beisert, a.) I had downloaded the kenel 2.6.X from the current site.if you are aware of any new kernel version for mini2440,please point me the same. b.) Yes.I got the path.You mentioned "Recent Linux 3.12.x" Is this will work for mini2440 ?coz i had seen only 2.6.x in this site. if no,how to make it compatible for mini2440. c.) As my intention is to work on drivers using mini2440,can you please tell me how to start and if any projects i can kickstart. Thanks for your reply :) Thanks, kalyan.k
> if you are aware of any new kernel version for > mini2440, please point me the same. Download the current Linux-3.12.x from kernel.org, build the defconfig for the Mini2440 and you are done. It does not support all devices on the board, but most of them > Is this will work for mini2440 ? Sure. > work on drivers using mini2440 What does it mean?
Hi, I was intersted in learning LDD,i had learned the concepts part.Now i want to practice on mini2440 board.As per my knowledge I2C driver is the simple one.I want to know the driver part of this,And if possible implementing some changes in the code(if found) OR found issues to be fixed Now i'm learning I2C subsystem.Can you tell me is this the way to learn the I2C drivers ? Please point me if any doc's/code which i can learn regarding the drivers Thanks, kalyan.
Where can we found the source code which is having issues and ppl post it fourms/ML's addressing those issues(if possible : I2C client/slave drivers / EEPROM using I2C) Please provide me the info.
