Moving from Mini2440 to 210s: Qt font too big
Ozzy
I currently changed from MIni2440 to 210s because of performance issues. I
am using the same Qt version (copied all files from the Mini2440 to the
210s) but have a problem with the font size. On the old board, the font
size was exactly like in the qt designer on the Linux host. But on the new
board (with the same A70 display) the font has about twice the size of the
"original" font size.
Does anyone of you has an idea what could be wrong with the new setup???
Thanks and best regards
Ozzy
Ozzy
No idea?
Maybe, show your printenv from the mini2440 and your printenv from the 210.
Also, when you said "copied all files from the Mini2440 to the
210s" ... specifically which files are you talking about?
Holger
take a look at this thread: http://www.friendlyarm.net/forum/topic/5753
I had the same problem and this solved mine.
Greetings
Holger
Ozzy
@davef: I copied the Qt libs and fonts and of course the executable
@Holger: thanks, maybe this is exactly what I need. I'll try this this when
I'm home. I thought the settings should be right when configuring the
setting of the flash "script" to the A70 display...
Best regards
Ozzy
Ozzy
This was absolutely the correct answer for me. But I had to multiply the
display size with 1.5... However it workes fine.
Ozzy
