Hi, I compile Qt application on system and I transfer application on mini2440 also I transfer tslib and Qt/lib files in usr/local folder. but still I got error in running application. please suggest some solution on this. With regard, rahul.
Qt application run error on mini2440
R u set env variable export QTDIR=/usr/local/Qt export TSLIB_CALIBFILE=/etc/pointercal export TSLIB_CONFFILE=/etc/ts.conf export TSLIB_CONSOLEDEVICE=none export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_PLUGINDIR=/usr/local/tslib/lib/ts export TSLIB_TSDEVICE=/usr/local/tslib/lib/ts export TSLIB_TSEVENTTYPE=INPUT
sushant: these environment variables parametrize the touchscreen library, but they do not help to make an application able to find this library.
