Hi everyone, I have mini2440 module.i want to access the GPIO port ,currently i dont have any cross compilers.If anyone have the free application(Linux) to access the GPIO port pls upload for me. With regards, Anadaraj
Accessing GPIO port
Unless you are not planning on doing further work on the mini2440, after this project , and you hope that you don't have to change anything if someone did supply a kernel that would allow you to access the GPIO ... then I'd suggest that you go here http://www.oselas.org/oselas/bsp/pengutronix/mini2440_bsp_en.html and spend the day or so getting setup properly. Are you sure the GPIO capability has not been enabled in your kernel? Maybe, tell us what you are currently running on the mini2440.
