ifup: don't seem to have all the variables for eth0/inet
bluscape
I get the following error when I configure my Mini2440 network settings for
DHCP:
When I have a static configuration it works fine.
Configuration example:
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
address 192.168.1.10
netmask 255.255.255.0
gateway 192.168.1.1
broadcast 192.168.1.255
What could cause this?
Juergen Beisert
Run "ifup" with "strace". Maybe it will show you what "ifup" tries to get
your interface up and running.
bluscape
I had a look. Would you mind having a look please? Thank you
execve("/sbin/ifup", ["ifup", "eth0"], [/* 19 vars */]) = 0
brk(0)                                  = 0xb2d000
uname({sys="Linux", node="mini2440", ...}) = 0
access("/etc/ld.so.preload", R_OK)      = -1 ENOENT (No such file or
directory)
open("/etc/ld.so.cache", O_RDONLY)      = -1 ENOENT (No such file or
directory)
open("/lib/tls/v4l/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat64("/lib/tls/v4l", 0xbea86368)      = -1 ENOENT (No such file or
directory)
open("/lib/tls/libc.so.6", O_RDONLY)    = -1 ENOENT (No such file or
directory)
stat64("/lib/tls", 0xbea86368)          = -1 ENOENT (No such file or
directory)
open("/lib/v4l/libc.so.6", O_RDONLY)    = -1 ENOENT (No such file or
directory)
stat64("/lib/v4l", 0xbea86368)          = -1 ENOENT (No such file or
directory)
open("/lib/libc.so.6", O_RDONLY)        = 3
read(3,
"\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\230X\1\0004\0\0\0"..., 512)
= 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=1209460, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) =
0x40062000
mmap2(NULL, 1246440, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0)
= 0x4014b000
mprotect(0x4026e000, 32768, PROT_NONE)  = 0
mmap2(0x40276000, 12288, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x123) = 0x40276000
mmap2(0x40279000, 9448, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40279000
close(3)                                = 0
0x40099000
set_tls(0x400994c0, 0x40099b98, 0x4011d048, 0x400994c0, 0x4011d000) = 0
mprotect(0x40276000, 8192, PROT_READ)   = 0
mprotect(0x4011c000, 4096, PROT_READ)   = 0
getuid32()                              = 0
brk(0)                                  = 0xb2d000
brk(0xb4e000)                           = 0xb4e000
open("/etc/network/interfaces", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=150, ...}) = 0
0x400cd000
read(3, "auto lo\niface lo inet loopback\n\n"..., 4096) = 150
read(3, "", 4096)                       = 0
close(3)                                = 0
munmap(0x400cd000, 4096)                = 0
open("/var/run/ifstate", O_RDONLY)      = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=6, ...}) = 0
0x400a7000
read(3, "lo=lo\n", 4096)                = 6
close(3)                                = 0
munmap(0x400a7000, 4096)                = 0
write(2, "ifup: don't seem to have all the"..., 57ifup: don't seem to have
) = 57
0x40060000
close(3)                                = 0
munmap(0x40060000, 4096)                = 0
open("/var/run/ifstate", O_WRONLY|O_CREAT|O_TRUNC, 0666) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=0, ...}) = 0
0x400a0000
write(3, "lo=lo\neth0=eth0\n", 16)      = 16
close(3)                                = 0
munmap(0x400a0000, 4096)                = 0
exit_group(1)                           = ?
bluscape
Anybody have any idea?
Tolun ARDAHANLI
When I try to up my nic than I get these errors. and lastly it is starting
to loop which shows that link goes up and down. Does any body have any
idea? Juergen Beisert? davef?
sincerely,
# ifup eth0
run-parts: /etc/network/if-pre-up.d: No such file or directory
eth0: link down
udhcpc (v1.13.3) started
udhcpc: exec /usr/share/udhcpc/default.script: No such file or directory
Sending discover...
Sending discover...
eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
Sending discover...
eth0: link down
No lease, failing
# eth0: link up, 10Mbps, half-duplex, lpa 0x0000
eth0: link down
eth0: link down
eth0: link down
eth0: link down
eth0: link down
eth0: link down
eth0: link down
eth0: link down
eth0: link down
eth0: link down
eth0: link down
bluscape
Ok, So I had to enable: PTXCONF_DHCP=y and enabled Install
/etc/dhclient.conf in ptxdist menuconfig, Network Tools->DHCP
Now it does not give that error anymore. Do not have DHCP here at the
moment, will test tonight.
Tolun ARDAHANLI
Hi bluscape;
I changed distro and everything is working well except touchscreen
calibration.
Do you know any easy solution for calibration of touchscreen?
Sincerely,
Juergen Beisert
Just found a reason for such an error message: Missing MAC address
bluscape
Hi Juergen,
Does this require the MAC in bootloader config or somewhere else?
Bootloader ip=none and all network related setting are disabled.
