Hi, I am trying to unmount the given system.img file and then create the system.img file again by using the following link, http://omappedia.org/wiki/Android_eMMC_Booting#Modifying_.IMG_Files Now trying to flash it on the NAND from the SDCARD. But I am unable to flash my own system.img. Its trying to write for while and the system hanged. However, the given system.img file from FriendlyARM is working charm. Kindly let me know if we have any specific format to create the img file for Tiny4412. I just like to do some modifications on the system files, create the img file again and write it on the NAND.
IMG format in Tiny4412
I found the solution for my query. Use the below command to create the IMG file for your mounted system folder, - Go to the android source folder - Now call the below command, #mkuserimg.sh -s <LOCATION OF YOUR SYSTEM IMG SOURCE FOLDER> <LOCATION OF YOUR NEW SYSTEM.IMG> ext4 system 314572800 -prakash
hi. i am a costomer of iran please help. we have tiny4412 of friendlyarm. we want programmed industrial progect on tiny4412 because we have not compiler for this board.
Dear Khodadad azizi you can make your owne application by Eclipse and Android sdk and jdk of course this is not to easy! i hope you made it.
