I purchased S3C2440 mini ARM board. i have a laptop. there is no serial port in the laptop. How to use the board without serial cable. ? how to flash the code in the board..? Can anybody help me. Any help will be appreciated.
regarding s3c2440 board
I purchased the serial to usb converter. When i started the board in nor flash, I m getting the message below Superboot-2440V1.1(20130529) by FriendlyARM Try to find SD card...... not found. Hello USB loop Can Anybody please help me how to start the board in NOR flash. Any help will be appreciated Thanks in advance.
Your board has Superboot. This means you should use a SD memory with the "images" directory on it, to flash a new OS image. This directory should be in your board's DVD.
As Ferite says, you program Superboott2440 from SD like 2451/6410/210/4412. But in NAND position your serial should show full Linux startup and end with a terminal login (you don't have to do anything, the terminal is already root).
