Hi. I am trying to adopt Mini2451 on my existing Mini2440 based design. On my current design, I use EINT0(GPF0) to EINT6(GPF6) pins of the Mini2440. However when I use the existing Mini2440 GPIO driver on the new Mini2451 board, all pins read as High. My questions are: 1. Is there some mapping changes on the register of S3C2451 that make the drivers read different registers?. 2. What happened with EINT6 pin?. On Mini2451's pin header, the numeration jumps from EINT5 to EINT11. 3. What other "surprises" can expect to work with GPIO and ADC on this new board?. Thanks for reading.
Do S3C2451 GPIOs have different register mapping?.
hello ferrite send me your email I would like to get in touch with you. alejandro_vargas_c@hotmail.com
I can only suggest that you might need to change something in your Matrix version linux-4.x.y/arch/arm/mach-s3c24xx/mach-mini2451.c and then re-compile. The hardware platform is defined in that file. I had a look for GPIO related stuff in it but the closest I can find are some definitions starting at line 416. Maybe one of the included files deals with the GPIO. Good luck!
... have a look at mach-mini2440.c in the same directory. I notice a file called #include <linux/gpio_keys.h> which isn't in mach-mini2451.c And #include <plat/gpio-cfg.h>, which isn't in mach-mini2440.c so maybe that is where to look for the mini2451
I develop software by VB2008.net
and this register I define for MINI2440
but, MINI2451 is not compatible?
What register address for PORT_F?
Some source code.
' Variable of Device
Private hPort As IntPtr
' Constant from GPIO Driver
Const PORT_A = &H0
Const PORT_B = &H10
Const PORT_C = &H20
Const PORT_D = &H30
Const PORT_E = &H40
'Const PORT_F = &H50 ' MINI2440 is work! but Mini2451 is not
work!!!
Const PORT_F = &H56000054 ' I try this register (I foud from
S3C2451_UM_REV1.pdf), but not work!
Const PORT_G = &H60
Const PORT_H = &H70
Const PORT_J = &H80
Const SET_OUTPUT = &H4
'Const SET_OUTPUT = &H1
Const SET_INPUT = &H3
Const GET_PIN = &H2
Const SET_PIN_ON = &H1
Const SET_PIN_OFF = &H0
Const SOUT As UInteger = &HFF ' set bit use for output
