System is an ODROID-X. root@odroid:/1/cuSDR32# uname -a Linux odroid 3.8.13.14 #1 SMP PREEMPT Sat Dec 21 22:14:31 UTC 2013 armv7l armv7l armv7l GNU/Linux root@odroid:/1/cuSDR32# cat /etc/os-release NAME="Ubuntu" VERSION="13.10, Saucy Salamander" ID=ubuntu ID_LIKE=debian PRETTY_NAME="Ubuntu 13.10" VERSION_ID="13.10" HOME_URL="http://www.ubuntu.com/" SUPPORT_URL="http://help.ubuntu.com/" BUG_REPORT_URL="http://bugs.launchpad.net/ubuntu/" The failures and the offending lines below. ------------------------------------------------------- g++ -c -pipe -g -Wall -W -D_REENTRANT -DQT_MULTIMEDIA_LIB -DQT_OPENGL_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++ -I. -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtNetwork -I/usr/include/qt4/QtGui -I/usr/include/qt4/QtOpenGL -I/usr/include/qt4/QtMultimedia -I/usr/include/qt4 -I/usr/include/QtMultimediaKit -I/usr/include/QtMobility -I. -Isrc -Isrc/AudioEngine -Isrc/CL -Isrc/DataEngine -Isrc/GL -Isrc/QtDSP -Isrc/Util -I/usr/X11R6/include -Ibld/moc -o bld/o/qtdsp_wpagc.o src/QtDSP/qtdsp_wpagc.cpp src/QtDSP/qtdsp_wpagc.cpp: In member function ‘void QWPAGC::ProcessAGC(CPX&, CPX&, int)’: src/QtDSP/qtdsp_wpagc.cpp:290:88: error: no matching function for call to ‘qMin(double, float)’ mult = (m_out_target - m_slope_constant * qMin(0.0, log10 (m_inv_max_input * m_volts))) / m_volts; ^ src/QtDSP/qtdsp_wpagc.cpp:290:88: note: candidate is: In file included from /usr/include/qt4/QtCore/qiterator.h:45:0, from /usr/include/qt4/QtCore/qvector.h:45, from /usr/include/qt4/QtCore/QVector:1, from src/QtDSP/qtdsp_qComplex.h:34, from src/QtDSP/qtdsp_wpagc.h:36, from src/QtDSP/qtdsp_wpagc.cpp:34: /usr/include/qt4/QtCore/qglobal.h:1213:34: note: template<class T> const T& qMin(const T&, const T&) Q_DECL_CONSTEXPR inline const T &qMin(const T &a, const T &b) { return (a < b) ? a : b; } ^ /usr/include/qt4/QtCore/qglobal.h:1213:34: note: template argument deduction/substitution failed: src/QtDSP/qtdsp_wpagc.cpp:290:88: note: deduced conflicting types for parameter ‘const T’ (‘double’ and ‘float’) mult = (m_out_target - m_slope_constant * qMin(0.0, log10 (m_inv_max_input * m_volts))) / m_volts; ^ src/QtDSP/qtdsp_wpagc.cpp: In member function ‘void QWPAGC::setHangLevelDb(qreal)’: src/QtDSP/qtdsp_wpagc.cpp:588:78: error: no matching function for call to ‘qMax(double, qreal)’ qreal tmp = qMax(1.0e-8, (convert - m_minVolts) / (m_maxInput - m_minVolts)); ^ src/QtDSP/qtdsp_wpagc.cpp:588:78: note: candidate is: In file included from /usr/include/qt4/QtCore/qiterator.h:45:0, from /usr/include/qt4/QtCore/qvector.h:45, from /usr/include/qt4/QtCore/QVector:1, from src/QtDSP/qtdsp_qComplex.h:34, from src/QtDSP/qtdsp_wpagc.h:36, from src/QtDSP/qtdsp_wpagc.cpp:34: /usr/include/qt4/QtCore/qglobal.h:1215:34: note: template<class T> const T& qMax(const T&, const T&) Q_DECL_CONSTEXPR inline const T &qMax(const T &a, const T &b) { return (a < b) ? b : a; } ^ /usr/include/qt4/QtCore/qglobal.h:1215:34: note: template argument deduction/substitution failed: src/QtDSP/qtdsp_wpagc.cpp:588:78: note: deduced conflicting types for parameter ‘const T’ (‘double’ and ‘qreal {aka float}’) qreal tmp = qMax(1.0e-8, (convert - m_minVolts) / (m_maxInput - m_minVolts)); ^ make: *** [bld/o/qtdsp_wpagc.o] Error 1 root@odroid:/1/cuSDR32# svn co http://svn.tapr.org/repos_sdr_hpsdr/trunk/DL3HVH/cuSDR32/ for the full source.
Problem with qreal, double and float porting an application
Think you have better luck here: http://forum.odroid.com/index.php
Thanks. I'll give that a try also but it's not only an ODROID problem, it's a general one on ARM. The same happens on Pandaboard and there are also many reports on Google, except I haven't found a way to fix this, but I have fixed a couple of others I came across.
Can you find where functions qMin and qMax are? I see those are preceded by template argument deduction/substitution failed: Are they just warnings? It may be ARM, but quite a different architecture. Good luck!
Apologies I have not looked here in quite a while. I got over the problem by recursively converting qreal to double. # find . -type f -print0 | xargs -0 sed -i 's/qreal/double/g' The next problem I have is with GL headers which seem to be incompatibility between the mali400 headers and mesa.
