Qt application development tslib/lib not found
rahul s
  I am developing Qt application for mini2440 using QtSDK for that I have
to configure mini2440 board means I have to put related libraries tslib &
Qt lib in mini2440.
  I follow the procedure given in following link
  http://qtinstall.blogspot.in/
  I follow the procedure I download tslib-1.4.tar.gz file and do the
procedure.I got Crosstslib folder at usr/local folder,but I wan'nt get
home/tslib folder.Because of this I wan'nt get tslib/lib files.
   Because of that my Qt application doesnt work on mini2440 board.
   Please suggest me some solution.
With regards,
Rahul.
Have a go with this tutorial:
http://mini2440vietnam.blogspot.co.nz/2011/04/upgrade-qt462-in-mini2440....
Ravi Kumar
Hi Rahul,
For support u can contact this email id raviyellani@gmail.com
rahul s
Attachment: error got.TXT (192 Byte)
  Thanks for reply. As I tried above given procedure and I got tslib/lib
file. which I transfer it to mini2440 board through pendrive but still I
got given error.(please find the attachment)
  Also I observe that in tslib/lib following files are there
  1) libts-1.0.so.0
  2) libts-1.0.so.0.0.0*
  3) libts.a
  4) libts.la
  5) libts.so
  6) pkgconfig/
  7) ts/
  But when I transfer it to board all file not get transfered libts.so file
missing.
   Will it make some problem?
  Waiting for reply.
With regards,
RAHUL.
Ravi Kumar
Zip and transfer the file
Tanny
  I want to develop Qt Applications on mini 2440 board but when i run my Qt
Application it gives the following error report. I spend really 3 weeks for
this still im not rectifying it. Please Help me.
#./fluidlauncher -qws
./fluidlauncher: error while loading shared libraries: libts-0.0.so.0:
cannot open shared object file: No such file or directory
Juergen Beisert
Then the libts-0.0.so.0 isn't available on your Mini2440 root filesystem.
Run your application with the tool 'strace' to get an idea where the
dynamic linker is searching in the filesystem for the libts.
rahul s
I also got same error.
rahul s
When I use strace command in mini2440 board it gives out an error 'command
not found'.
Juergen Beisert
Guess what "command not found" means: if its is not present on your system,
you must install it.
