Hello, I am using this command for set RTC time date +%T -s "11:56" its show invalid date .. How to update time
How to update RTC time in mini2440
Actually, on advice from Juergen it is more appropriate to set your hwclock to UTC and then date will be correct for your current timezone. So, what I now do is: set date correctly to your current date and time and then hwclock -u --systohc effectively setting your hwclock to UTC based on the system time (date).
Let's try this again ... your title is inconsistent with your procedure. I can't set RTC time with the date command (At least as far as I can see). hwclock sets your RTC time, but also you can set the system time (date) with it.
hwclock --set --date "02/19/2013 15:00:00"
hwclock: unrecognized option '--set'
BusyBox v1.13.0 (2009-07-29 12:03:34 CST) multi-call binary
Usage: hwclock [-r|--show] [-s|--hctosys] [-w|--systohc] [-l|--localtime]
[-u|--utc] [-f FILE]
Query and set hardware clock (RTC)
Options:
-r Show hardware clock time
-s Set system time from hardware clock
-w Set hardware clock to system time
-u Hardware clock is in UTC
-l Hardware clock is in local time
-f FILE Use specified device (e.g. /dev/rtc2)
its return help content any extra package for date command
Sorry, that was for Ubuntu. hwclock in Ubuntu and Busybox are slightly different. Set date then hwlock -uw as in the other thread http://www.friendlyarm.net/forum/topic/828
Options:
same mas show.
thanks
It looks like your Busybox doesn't recognise --systohc as -w option?? hwclock -u --systohc works for me. Did you try hwclock -uw as mentioned Also, my Busybox version is 1.21.0 What do you get when you try: date Do you get your local time and date? Setting date: date -s "2013-10-18 08:23"
So, you know what the "time" was before it was reset? First, do: date -s "2013-10-18 08:23" then on the command line type in date and hit enter ... what do you see?
Hello, hwclock -w Set on rcS file then poweroff the system for 1hr and check date is show Wed Dec 31 19:00:16 EST 1969 means its not permantly set time... i am very confuse my application is fully works on rtc and write current time on file . for this problem i am not able to write file in current date & time ...
Show us the rcS file. In the early FA distro some of these files were mounted in tmpfs, which then meant they were volatile. So, copy and paste the whole file for us to look at.
Hi! Here is simple script which update RTC on Linux OS on FriendlyArm Mini2440. Usage: 1. Copy script to FriendlyArm by FTP (use binary transfer mode) 2. Change permission (chmod 777 setTime) 3. Run it with ./setTime 22 12 1985 15:50:14 Also check RTC battery.
> What is your experience? Distributing a binary is only "it works for you". For all other people its another source of pain.
Hi Milan, thanks a lot for your script already frustrated on my boards though. it works like a charm for me. Regards, Well. wellson.octo@gmail.com
For sushaunt error :
Options:
I have the same error like you.
At first i do that : # date -s "2016-05-31 13:23"
then write this : # date -s "2016-05-31 13:23"
then both of them set the same
source :
https://access.redhat.com/documentation/en-US/Red_Hat_Enterprise_Linux/7...
