I am really new at this.I recently migrated from Fedora 17 to Ubuntu 12.04. I was trying to run a led program on the target (i.e. my mini2440) when the following error came up. At the time I was in the root of the target. Further Note: I issued permission to the output file using the following command chmod 777 led yet it is still a no go. What am I missing ? I would also like to know if there is a listing of the various commands that the mini accepts ? Forgive me is this is basic stuff as I am just starting out. -sh: ./led: Permission denied
-sh: ./led: Permission denied mini2440
You are likely to be running Busybox, so check out <Busybox help> in Google. You have checked that there is actually a binary called led somewhere on the target? I would find it and then in that directory issue your command ./led and see if that works Maybe, the path is not in the normal list of places to find things. Do you have led on a host machine? Then try readelf -a and check the last few lines ... you want to see arm4vt somewhere.
